I have installed mininet. And I am trying to create network and to add hosts with mininet but I got the error: sudo mn [sudo] password for udooer: *** Creating network *** Adding controller *** Adding hosts: h1 h2 *** Adding switches: s1 *** Adding links: -------------------------------------------------------------------------------- Caught exception. Cleaning up... Exception: Error creating interface pair (h1-eth0,s1-eth1): RTNETLINK answers: Operation not supported I think something is missing in the kernel configuration. Which parameters am I supposed to activate? Here is my corresponding .config file part # # Core Netfilter Configuration # CONFIG_NETFILTER_NETLINK=m # CONFIG_NETFILTER_NETLINK_ACCT is not set # CONFIG_NETFILTER_NETLINK_QUEUE is not set CONFIG_NETFILTER_NETLINK_LOG=m CONFIG_NF_CONNTRACK=y # CONFIG_NF_CONNTRACK_MARK is not set CONFIG_NF_CONNTRACK_PROCFS=y # CONFIG_NF_CONNTRACK_EVENTS is not set # CONFIG_NF_CONNTRACK_TIMEOUT is not set # CONFIG_NF_CONNTRACK_TIMESTAMP is not set # CONFIG_NF_CT_PROTO_DCCP is not set # CONFIG_NF_CT_PROTO_SCTP is not set # CONFIG_NF_CT_PROTO_UDPLITE is not set # CONFIG_NF_CONNTRACK_AMANDA is not set # CONFIG_NF_CONNTRACK_FTP is not set # CONFIG_NF_CONNTRACK_H323 is not set # CONFIG_NF_CONNTRACK_IRC is not set # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set # CONFIG_NF_CONNTRACK_SNMP is not set # CONFIG_NF_CONNTRACK_PPTP is not set # CONFIG_NF_CONNTRACK_SANE is not set # CONFIG_NF_CONNTRACK_SIP is not set # CONFIG_NF_CONNTRACK_TFTP is not set # CONFIG_NF_CT_NETLINK is not set # CONFIG_NF_CT_NETLINK_TIMEOUT is not set CONFIG_NF_NAT=m CONFIG_NF_NAT_NEEDED=y # CONFIG_NF_NAT_AMANDA is not set # CONFIG_NF_NAT_FTP is not set # CONFIG_NF_NAT_IRC is not set # CONFIG_NF_NAT_SIP is not set # CONFIG_NF_NAT_TFTP is not set # CONFIG_NF_TABLES is not set CONFIG_NETFILTER_XTABLES=y # # IP: Netfilter Configuration # CONFIG_NF_DEFRAG_IPV4=m CONFIG_NF_CONNTRACK_IPV4=m CONFIG_NF_CONNTRACK_PROC_COMPAT=y CONFIG_IP_NF_IPTABLES=m # CONFIG_IP_NF_MATCH_AH is not set # CONFIG_IP_NF_MATCH_ECN is not set # CONFIG_IP_NF_MATCH_RPFILTER is not set # CONFIG_IP_NF_MATCH_TTL is not set CONFIG_IP_NF_FILTER=m CONFIG_IP_NF_TARGET_REJECT=m # CONFIG_IP_NF_TARGET_SYNPROXY is not set CONFIG_IP_NF_TARGET_ULOG=m CONFIG_NF_NAT_IPV4=m CONFIG_IP_NF_TARGET_MASQUERADE=m CONFIG_IP_NF_TARGET_NETMAP=m CONFIG_IP_NF_TARGET_REDIRECT=m # CONFIG_NF_NAT_PPTP is not set # CONFIG_NF_NAT_H323 is not set CONFIG_IP_NF_MANGLE=m # CONFIG_IP_NF_TARGET_CLUSTERIP is not set # CONFIG_IP_NF_TARGET_ECN is not set # CONFIG_IP_NF_TARGET_TTL is not set CONFIG_IP_NF_RAW=m CONFIG_IP_NF_ARPTABLES=m CONFIG_IP_NF_ARPFILTER=m CONFIG_IP_NF_ARP_MANGLE=m
