hello o dont knkow if this is the right section for this but i tried to do the carmadillo project (http://www.udoo.org/ProjectsAndTutorial ... lioID=1368) and i'm stuck with the rtsp server when i use the make command on the terminal it gives me the error on the image and i dont know what to do(i'm a linux noob) can anybody help me?
well i solved the problem intalling the gstreamer-dev but now when i use "make" it doesn't compile and says "libxml/parser.h no such file or directory " i tried installing the libxml-dev but it didn't change anything, does anybody know whats the error, or other good way to do a rtsp server to stream to android ?
Ffmpeg should be able to encode and stream your video. I use it to stream a camera video via UDP like this : Code: ffmpeg -f video4linux2 -video_size 320x240 -framerate 30 -input_format yuyv422 -i /dev/video0 -vcodec libx264 -preset ultrafast -f mpegts udp://10.133.7.43:1337 Here is a link to the ffmpeg documentation, there is an exemple of audio stream using rtsp, I guess you only have to change it a bit to stream video instead : https://trac.ffmpeg.org/wiki/StreamingGuide#StreamingasimpleRTPaudiostreamfromFFmpeg
Hi, I got the rtsp server to compile with make on UDOObuntu v1.0 after installing all the dependencies listed on the tutorial: Code: sudo apt-get install libgstreamer0.10-dev libgstrtspserver-0.10-dev build-essential git Now, does anyone know which is the URL is for accessing the stream using VLC ? Thanks
hey, I know I replying late but this might help you : rtsp-sever-send-image-android-t1170.html Good Luck
