Safe to run from 13.8V power source?
Discussion in 'UDOO X86' started by Jarno Paananen, Jul 25, 2017.
  1. Jarno Paananen
    Jarno Paananen New Member
    Jul 25, 2017
    I plan on running my observatory with UDOO X86 Ultra I got and would just like a confirmation if it's safe to run from the same 13.8V power source I use to power all the other equipment there or do I have to provide a strictly 12V source somehow. The documentation says 12V +- 5% which is fairly strict as 12V equipment usually is fine with 13.8V as well. I tried to decipher the schematics and as far as I can tell from the data sheets for the power converter chips should be able to handle it (RT8231AGQW Vin Max is 26V, RT7243GQW 18V, RT7231GQW 18V, RT8175AGQW 25V, RT8297B 17V). I don't plan on using SATA disk which I guess would use the 12V line as such.
  2. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    92
    SATA power doesn't have 12 V at all - only 5V.
  3. ccs_hello
    536
    194
    Your assessment is probably correct.
    Except that it is inconsistent with the factory provided spec thus I would not recommend publicizing it.
    Best approach is to use this approach: YMMV.
  4. mkopack
    mkopack Member
    451
    I would definitely NOT recommend it... Or at least, don't expect good things to happen if you try.
