Log in to your Neo and monitor /dev/ttyMCC: cat /dev/ttyMCC Run this program on the Arduino: Code: void setup() { Serial.begin(115200); pinMode(13, OUTPUT); } void loop() { digitalWrite(13, HIGH); Serial.print("High\n"); delay(50); digitalWrite(13, LOW); Serial.print("Low\n"); delay(50); } Watch the output. After a series of High and Lows, and flashing of the onboard led you'll see that the led stops flashing and no additional output will be written to the serial.
Did you tried Code: minicom -D /dev/ttyMCC or the Arduino IDE Serial Monitor? cat /dev/ttyMCC is known to be problematic with MCC. ek5
No, I didn't. The reason I tried this is because I encountered problems with serial communication before. In my program I used to read /dev/ttyMCC and indeed I had problems with that. Now I use the RXXT Java library, but still I link /dev/ttyMCC to /dev/S0 in order to read from it. Isn't that the right way?
Can I assume safely that it will be a while before these serial problems are solved: https://trello.com/b/dPL55Pnt/udoo-neo-roadmap
It could be, if I follow the rules in my issue I have no issues but I did not test it for more than 8 hours. I also use python to read and not bash cat. If you use minicom or Arduino IDE serial monitor do you experience the same failure? With python there is also an issue that you have to use the proper serial library (python-serial, now preinstalled on rc2). Perhaps a similar library issue is on Java?
