SATA Drive not found @ /dev/sda
Discussion in 'General Discussion' started by winsonlcc, Aug 12, 2015.
Thread Status:
Not open for further replies.
  1. winsonlcc
    winsonlcc New Member
    Oct 30, 2014
    Hi, I failed to get the /dev/sda when I plug in a good drive 2.5" SATA drive 320GB in my latest UDOO-Quad. Drive was spin, can feel it so power no issue. I using the SATA cable and the power supply 5V cable.
    If I use the SATA to USB adapter plug in into UDOO USB port, then I found the /dev/sda with drive initialize information.
    I had a project to develop for hard disk drive screening test which using SATA cable port. Please help whether any setting I miss out, why no /dev/sda appear when drive plug in?
    P/S: I'm not using SATA HDD to boot the system, I used SATA drive as extra external storage only. So I need to know how the setting for it. Using SATA-USB adapter no issue.
    Thanks
    Winson
  2. winsonlcc
    Oct 30, 2014
    HI all,
    i manage to detect the HDD. :)
    This thread can removed. Thanks
  3. delba
    1,064
    Not removed. closed ;)
Thread Status:
