Sata Power
Discussion in 'General Discussion' started by ottyphc, Oct 14, 2013.
  1. ottyphc
    ottyphc New Member
    Jun 27, 2013
    27
    Udoo has a 5 volt power connector (j12) to supply power to a sata device. Does anyone know how muck current can be drawn from this connector? Also, is there a suitable power cable available that can be used to connect power from j12 to a sata hdd?
  2. mkopack
    mkopack Member
    451
    I doubt you're going to find something pre-made that will work for the power portion.
    Your best bet will probably be to find one of those 4-pin (old style hard drive power) Molex --> sata power cables, and then cut the connector off and solder the +5V and GND wires into a new connector that will fit onto J12.
  3. mkopack
    mkopack Member
    451
    And FYI, I'll probably be doing the same as soon as I receive my unit...
  4. saidol
    saidol New Member
    Oct 3, 2013
    24
    search for a thread whit subject:
    "SATA Power on quad?"
    in Board index->Community ->General Discussion
    viewtopic.php?f=2&t=66
    bye
    Giuseppe
