SD image ArchLinux for Udoo Quad
Discussion in 'Other OS' started by ProCoPrint3D, Dec 27, 2014.
  1. ProCoPrint3D
    ProCoPrint3D New Member
    Nov 27, 2014
    22
    Can someone make an image to the SD card ArchLinux for Udoo Quad ?
    I ask because I do not have the strength to try to test and combine.
    I'm doing a CNC machine and I want to insert the control board there Udoo so far without success.
    I must have Printrun control program, this program is in ArchLinux. Please help.
  2. delba
    1,064
    Sorry, but you can make your own ArchLinux image, some info here: http://archlinuxarm.org/
    Ps. Next time avoid to post the same thing 3 times, thanks.
  3. LDighera
    LDighera UDOOer
    Jan 13, 2014
    206
    36
    There is even more Udoo-specific information here: http://archlinuxarm.org/platforms/armv7/freescale/udoo.
    I have a version of Arch Linux I generated on an 8GB card in March 2014 (not the latest version of Arch, no X11 or functional WiFi) from which I could generate an ISO image for you, but I'd suggest you opt to use a later release.
    If you have difficulty following the instructions at the link above, post here, and I'll see if I can be of assistance.
  4. ProCoPrint3D
    Nov 27, 2014
    22
    I have tried many different ways and different builds of Linux, but board Udoo does not want to cooperate software Printrun.
    Now I bought this motherboard and everything works. http://reprapworld.com/?products_details&products_id/478/cPath/1626
    How I'll have time, inserting the instructions to install and compile Archlinux and other versions of Linux and Printrun. Maybe someone will want to test and run, I was subjected to the test after a month.
