Sending file through bluetooth crontab
Discussion in 'UDOO NEO' started by CCT, Jun 14, 2016.
  1. CCT
    CCT New Member
    Apr 21, 2016
    11
    I want to send a file named "read.txt" using command: bluetooth-sendto. It works using the direct command on terminal "bluetooth-sendto --device=MACADDR path/to/read.txt". I want to execute it with this cron job:
    */1 * * * * bluetooth-sendto --device=MACADDR path/to/read.txt
    But it doesn't work. Redirecting the output of this command results an empty file:
    */1 * * * * bluetooth-sendto --device=MACADDR path/to/read.txt>path/to/err.log
    Permissions of directories and files are 777. Cronjob is settled for same user that can execute command from command line directly.
  2. CCT
    CCT New Member
    Apr 21, 2016
    11
    I need to send data between two udoo through bluetooth...
  3. Laura
    Laura UDOOer
    Apr 22, 2016
    374
    156
    Can you clarify the process you're following on the receiving device, for the direct command and for the Cron job?
  4. CCT
    CCT New Member
    Apr 21, 2016
    11
    On the receiving device i'm not following any process. When I send the the file through command line it works fine and the other board receives the file.
  5. waltervl
    The path to Read.txt is a complete path? So /home/user/udooer/read.txt
  6. CCT
    CCT New Member
    Apr 21, 2016
    11
    The path is /home/udooer/reads.txt, and that is also the path that i used. Sorry if I wrote user.
  7. waltervl
  8. CCT
    CCT New Member
    Apr 21, 2016
    11
    I also tried to put the command in a script and then try to launch that, but it doesn't work. I tried with other commands but I don't have this problem with them. Can still be a problem of the path?
  9. CCT
    CCT New Member
    Apr 21, 2016
    11
    From the log file of the crontab:
    Jun 16 14:26:01 localhost CRON[2023]: (udooer) CMD (bluetooth-sendto --device=xx:xx:xx:xx:xx:xx /home/udooer/send.txt)
    Jun 16 14:26:01 localhost CRON[2016]: (CRON) info (No MTA installed, discarding output)
  10. CCT
    CCT New Member
    Apr 21, 2016
    11
    There are other ways for two udoos to communicate with Bluetooth?
  11. waltervl
  12. CCT
    CCT New Member
    Apr 21, 2016
    11
    Thank you so much. This command solve my problem: obexftp –-nopath –-noconn –-uuid none –-bluetooth <BTAddr> –-channel <OPUSHChannelNo> –put <FileToPut>.
    Do you know if the channel is fixed or if it changes every time I shut down the device?
  13. waltervl
    I have no idea, just did a quick google search to help you :)
    Andrea Rovai likes this.
  14. CCT
    CCT New Member
    Apr 21, 2016
    11
    Yesterday all worked well, now I'm getting this error:
    Suppressing FBS.
    Connecting..\done
    Tried to connect for 536ms
    Sending "/home/user/send.txt"...|failed: /home/user/send.txt
    The operation failed with return code 67
    Disconnecting../done
    Help?
  15. CCT
    CCT New Member
    Apr 21, 2016
    11
    I can't send files with gui...
