I can't seem to get serial communications to work as expected from UDOO Dual to Arduino. I am using serial to prompt user for input. Code: Serial.print("Enter 8bit value: "); r=Serial.parseInt(); My baud rate is 115200. I tried terminal commands found here to set the baud and serial settings but didn't work: http://www.udoo.org/ProjectsAndTutorials/interaction-between-linux-and-arduino-on-udoo/
Did you use stty -F /dev/ttymxc3 cs8 115200 ignbrk -brkint -icrnl -imaxbel -opost -onlcr -isig -icanon -iexten -echo -echoe -echok -echoctl -echoke noflsh -ixon -crtscts ? Try with sudo or root privileges
