shutdown after 3 songs and spdif out problem
Discussion in 'Troubleshooting' started by sonics, Jan 11, 2014.
  1. sonics
    sonics New Member
    Jan 11, 2014
    Hello,
    I use udoo with volumio and
    before telling problems i must say that SQ is phantastic.
    1.But..... udoo is stopping always after 5 to 10 min.
    Only resetbutton helps restarting and then it works for 10 mn. I tried all kernels and options.
    What can i do? Defekt board or software problem?
    2.How i can get spdif out. At the moment only hdmi out is possible and usb out is not compatible with my nad M51?
    Is it a special volumio problem or the lack of linux drivers.
    Thank You
    Alfred
    Frankfurt germany
  2. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Which PSU do you use? Could be a psu issue... Is the same with other software?
    I'm working to get spdif out... Just be patient...
  3. sonics
    sonics New Member
    Jan 11, 2014
    I used several PSUs with the same result.
    I found out that the board shuts down after ten minutes only when using hdmi out with volumio.
    With usb-out there is no problem, but i need hdmi for audio.
