Sketch Arduino Problem
Discussion in 'UDOO X86' started by Carles, May 8, 2017.
  1. Carles
    Carles New Member
    May 8, 2017
    I’ve a problem with Arduino’s Sketch.
    My operating system is Ubuntu 16.0.4 and I use IDE Arduino 1.8.2
    Note that IDE detects correctly my port à /dev/ttyACM0 (Arduino/Genuino101)
    But everytime I run the sketch appears the next message:
    Although sometimes appears this another message:
    I’m trying execute arduino_serial_example.ino to start testing the board.
    Do you have any suggestion how to fix that?
    Thanks for your help
  2. MikeSD
    MikeSD New Member
    May 22, 2016
    11
  3. Carles
    Carles New Member
    May 8, 2017
    I only add my user to the dialout group.
    Tomorrow I'll try follow the post to add udev rule. I'll Inform you.
    Thanks a lot
  4. tuxun
    tuxun Member
    Dec 20, 2013
    67
    12
    Hi. i think Mike speak about this part:
    sudo usermod -a -G dialout $USER
    wget https://github.com/01org/intel-arduino-tools/raw/linux64/scripts/create_dfu_udev_rule
    chmod +x create_dfu_udev_rule
    sudo ./create_dfu_udev_rule
    rm create_dfu_udev_rule
    (which solved my problem of timeout under ubuntu, me too)
    kfly likes this.
  5. Carles
    Carles New Member
    May 8, 2017
    It works properly.
    Thank you very much
    MikeSD likes this.
  6. MikeSD
    MikeSD New Member
    May 22, 2016
    11
    Glad that worked, I struggled with it for a while till I found the post I linked. They should really have put this in the X86 guide. So at least people using ubuntu or distros based off of ubuntu wouldn't have to go looking for the solution.
    Mike
  7. waltervl
