SoftwareSerial error
Discussion in 'UDOO NEO' started by thalespi, Apr 11, 2016.
  1. thalespi
    thalespi New Member
    Mar 27, 2016
    10
    I'm trying to use SoftwareSerial on Udoo Neo but it says:
    sketch_apr10a.ino:1:28: fatal error: SoftwareSerial.h: No such file or directory
    compilation terminated.
    Error compiling.
    Also, when I try using Serial1, it gives me:
    sketch_apr10a.ino: In function 'void setup()':
    sketch_apr10a:5: error: 'Serial1' was not declared in this scope
    What am I doing wrong ?
  2. ektor5
    Jul 1, 2013
    97
    48
    Hi there,
    I'm sorry, but SoftwareSerial is not supported by UDOO Neo. BTW, what do you need that for?
    If you need access to another serial (hw pins 0-1), just use Serial0 instance instead.
    Hope this helps,
    Ek5
  3. thalespi
    thalespi New Member
    Mar 27, 2016
    10
    Well, I want to use that code to configure a BT Module:
    /*-----( Import needed libraries )-----*/
    #include <SoftwareSerial.h>
    /*-----( Declare Constants and Pin Numbers )-----*/
    #define HC_05_TXD_ARDUINO_RXD 2
    #define HC_05_RXD_ARDUINO_TXD 3
    #define HC_05_SETUPKEY 4
    #define HC_05_PWR1 5 // Connect in parallel to HC-05 VCC
    #define HC_05_PWR2 6 // Connect in parallel to HC-05 VCC
    /*-----( Declare objects )-----*/
    SoftwareSerial BTSerial(HC_05_TXD_ARDUINO_RXD, HC_05_RXD_ARDUINO_TXD); // RX | TX
    /*-----( Declare Variables )-----*/
    //NONE
    void setup() /****** SETUP: RUNS ONCE ******/
    pinMode(HC_05_SETUPKEY, OUTPUT); // this pin will pull the HC-05 pin 34 (key pin) HIGH to switch module to AT mode
    pinMode(HC_05_PWR1, OUTPUT); // Connect in parallel to HC-05 VCC
    pinMode(HC_05_PWR2, OUTPUT); // Connect in parallel to HC-05 VCC
    digitalWrite(HC_05_SETUPKEY, HIGH); // Set command mode when powering up
    Serial.begin(9600); // For the Arduino IDE Serial Monitor
    Serial.println("YourDuino.com HC-05 Bluetooth Module AT Command Utility V1.02");
    Serial.println("Set Serial Monitor to 'Both NL & CR' and '9600 Baud' at bottom right");
    Serial.println("Vcc Power Up DELAY");
    delay(2000);
    Serial.println("Applying VCC Power. LED should blink SLOWLY: 2 Seconds ON/OFF");
    digitalWrite(HC_05_PWR1, HIGH); // Power VCC
    digitalWrite(HC_05_PWR2, HIGH);
    delay(2000);
    Serial.println("Enter AT commands in top window.");
    BTSerial.begin(38400); // HC-05 default speed in AT command mode
    }//--(end setup )---
    void loop() /****** LOOP: RUNS CONSTANTLY ******/
    // READ from HC-05 and WRITE to Arduino Serial Monitor
    if (BTSerial.available())
    Serial.write(BTSerial.read());
    // READ Arduino Serial Monitor and WRITE to HC-05
    if (Serial.available())
    BTSerial.write(Serial.read());
    }//--(end main loop )---
    /*-----( Declare User-written Functions )-----*/
    //NONE
    //*********( THE END )***********
  4. waltervl
    If you connect the serial pins of your Bluethooth module to pin 0 and 1 instead of 2 and 3 you can use the hardware serial Serial0 instead of SoftwareSerial (btserial). I think you cannot plug it in directly then but have to rewire a little bit.
    delba likes this.
  5. thalespi
    thalespi New Member
    Mar 27, 2016
    10
    Got it to work, thanks
