[SOLVED] Bios Update get errors
Discussion in 'UDOO X86' started by Walter, Dec 3, 2018.
  1. Walter
    Walter New Member
    Dec 3, 2018
    Hello,
    I bought a Udoo x86 Basic Board and want to update the Bios to 1.05 because the Bios version I have can't write SD cards yet. I have a FreeDos USB stick and I can start it. After calling the Update.bat I always get the following error: "allocate Physical Memory failed (buffer2)" The update will not be done...
    what can I do?
    thank you for your help
    regards Walter
  2. ektor5
    Jul 1, 2013
    97
    48
    Hi @Walter,
    Probably FreeDos is not compatible with the updater at the moment.
    If you can, please use an Ubuntu distribution (e.g. Ubuntu 18.04) or Windows 10 and the correspondent tool.
    Best Regards,
    Ek5
  3. Walter
    Walter New Member
    Dec 3, 2018
    Hi @Ek5,
    thank you very much for your answer. Then I could still try for a long time.........
    I tried it with a MS-Dos stick and loaded the Bios version 1.04 that worked.
    That is ok for me, because the SD card and also the battery reset should work with it.
    Ev. goes with MS-Dos also the 1.05? Maybe I still try it out?
    greetings
    Walter
  4. ektor5
    Jul 1, 2013
    97
    48
    Yes, BTW the only improvement shipped with 1.05 is the SPDIF feature enabled.
    Regards,
    Ettore
