[solved] booting from sata
Discussion in 'Troubleshooting' started by schnabelvieh, Jan 18, 2015.
  1. schnabelvieh
    schnabelvieh New Member
    Jan 18, 2015
    Hello All,
    i'm new to this forum and really new to embedded linux. I've been trying for quite a while to figure out how to boot from a sata disk. Well, I didn't succeed. My aim is to install a gentoo-distro.
    The following is the partition-layout of my sata disk:
    /dev/sda1          20480    307199    143360  83 Linux
    /dev/sda2         307200  20787199  10240000  82 Linux swap / Solaris
    /dev/sda3       20787200 234440703 106826752  83 Linux
    and my fstab:
    /dev/sda1               /boot           ext2            noauto,noatime  1 2
    /dev/sda3               /               ext4            noatime         0 1
    /dev/sda2               none            swap            sw              0 0
    /dev/cdrom              /mnt/cdrom      auto            noauto,ro       0 0
    /dev/fd0                /mnt/floppy     auto            noauto          0 0
    proc                    /proc           proc     defaults        0 0
    sysfs                   /sys            sysfs     defaults        0 0
    I've tried several things.
    1) I used the unico Kernel, which is available at git. I compiled the kernel using the config from
     cat /proc/config.gz
    from a running UDOObuntu_quad_v1.1.zip
    I compiled it with
     make -j5 LOADADDR=0x12000000  uImage
    , copied it to my boot-partition which is /dev/sda1 and did all the uboot - commands step by step to make sure the kernel would be found.
    NOTE: The kernel was done in a "chrooted" environment with a fresh gentoo stage 3 installation.
    Unfortunately that was all I was able to achieve. The boot process stopped imediately after the Kernel Welcome Message "Starting Kernel" was issued.
    2) I copied the kernel form a running UDOObuntu_quad_v1.1.zip to my boot-partition, modyfied the uboot variables to
     sataargs=setenv bootargs console=${console},${baudrate} root=${sataroot} ${hdmi_patch} ${memory} ${video}
    sataboot=if sata init; then echo Booting from sata ...; run sataloaduimage; run sataargs; bootm; else sata boot failed; fi
    satadev=0
    sataloaduimage=ext2load sata 0:1 0x12000000 uImage
    satapart=1
    sataroot=/dev/sda3
    and did a run sataboot.
    This time the kernel booted until it stopped with
    NOTE: On my sata disk was a fresh gentoo stage 3 installation.
    [    3.026253] snvs_rtc snvs_rtc.0: setting system clock to 2015-01-18 17:22:14 UTC (1421601734)
    [    3.035514] VFS: Cannot open root device "sda3" or unknown-block(0,0)
    [    3.041971] Please append a correct "root=" boot option; here are the available partitions:
    [    3.050342] b300        15558144 mmcblk0  driver: mmcblk
    [    3.055675]   b301         6803527 mmcblk0p1 00000000-0000-0000-0000-000000000000
    [    3.063248] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
    [    3.071551] [<800475d4>] (unwind_backtrace+0x0/0xfc) from [<8065e690>] (panic+0x74/0x19c)
    [    3.079750] [<8065e690>] (panic+0x74/0x19c) from [<80008cc4>] (mount_block_root+0x16c/0x220)
    [    3.088204] [<80008cc4>] (mount_block_root+0x16c/0x220) from [<80008e50>] (mount_root+0xd8/0xf4)
    [    3.096998] [<80008e50>] (mount_root+0xd8/0xf4) from [<80008f8c>] (prepare_namespace+0x120/0x184)
    [    3.105899] [<80008f8c>] (prepare_namespace+0x120/0x184) from [<800083dc>] (kernel_init+0x108/0x144)
    [    3.115053] [<800083dc>] (kernel_init+0x108/0x144) from [<80041080>] (kernel_thread_exit+0x0/0x8)
    [    3.123941] CPU1: stopping
    Well, mmm, what I don't understand is the fact, that I'm offered a couple of partions from the sd card and not from the sata disk. Is the kernel missing some sata-support?
    Can anybody give me a hint ?
    Thanks in advance and have a nice evening,
    schnabelvieh
  2. schnabelvieh
    Jan 18, 2015
    Hello again,
    well, it is up and running now ;-) I copied my gentoo installation to a root partition with an ext3 filesystem instead of an ext4 filesystem. I dont't know wether this is a kernel-configuration or a uboot-configuration problem.
    My uboot - image is the U-Boot 2013 release 2.1 available at udoo.org, the kernel is still identical to the one used in the UDOObuntu_quad_v1.1.zip release.
    Haven't tried yet with a self-compiled unico kernel.
    Have Fun,
    schnabelvieh
  3. delba
    1,064
    schnabelvieh, glad you solved your issue, and thanks to sharing it with us ;)
