[Solved] RAM Missing.... 621.6mb RAM ???
Discussion in 'General Discussion' started by asvaldr, Oct 19, 2013.
Thread Status:
Not open for further replies.
  1. andcmp
    andcmp New Member
    161
    Re: RAM Missing.... 621.6mb RAM ???
    We are already aware about the missing RAM issue. In the next uBoot release this problem will be solved.
  2. josolanes
    josolanes New Member
    Oct 14, 2013
    64
    Great, thanks @andcmp!
  3. mkopack
    mkopack Member
    451
    Can I make a suggestion (both so you guys don't get hammered with it, and we don't have to see the same 100 questions posted over and over)?
    Make a "Known issues and workarounds" page somewhere on the website and sticky the link to it on the forums so people are aware of what the current known problems are and any possible solutions there are to those issues.
  4. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    [Poker terminology coming up]
    I see your 'known issues' page and raise you ' Bug Tracker/Ticket System'
    Obviously there is a Bug Tracker going for this project, why not allow the community read access? I'm sure it will a) be much appreciated, b) lower frustration levels, c) ease the workload off the devs in responding to known issues (even if someone does ask, the community can answer 'that is known' on your behalf).
  5. firehopper
    firehopper Member
    Jun 10, 2013
    154
    maybe also make the beta testers forums avail? since this is almost still a beta hardware/software thing? software is prolly closer to beta than the hardware part.
  6. mkopack
    mkopack Member
    451
    Call!
  7. Roberto
    Roberto New Member
    Jun 15, 2013
    Just tested something. Using serial I prevented the boot and changed the "memory" variable to 1024M instead of 768M, and now I get "Mem: 896576k total" using top.
    Don't know if its real memory, but Linux will fail to boot if I try to change it to more than 1024M.
  8. josolanes
    Oct 14, 2013
    64
    @Roberto - that's great! So it seems it was just a typo when building uBoot?
  9. Roberto
    Roberto New Member
    Jun 15, 2013
    @josolanes
    I don't really know, but if you want to test open the serial connection, power on UDOO, when it starts counting down press any key to stop.
    Type "setenv memory mem=1024MB", then "saveenv" and finally "boot".
  10. josolanes
    Oct 14, 2013
    64
    @Roberto
    I'll likely give this a try Thursday, next day I'm really available unfortunately - the wait is driving me crazy!
  11. saidol
    saidol New Member
    Oct 3, 2013
    24
    Hi all,
    memory layout of uDOO is currently configured as below.
    Total memory on the board = 1024 Mega (4 banks x 256 Mega).
    (A schematics was developed to support future release with 2048 Giga, but currently configuration is with only 1 Giga).
    At boot kernel parameters limit available kernel memory to 768 Mega (mem=768M parameter)
    Moreover Freescale suggest to reserve 128 Mega for GPU activity (Line 1244 of sabresd platform file http://tinyurl.com/pc96ml5 ), so also in uDOO kernel source you can find a correspondent line in: arch/arm/mach-mx6/board-mx6_seco_UDOO.c
    (http://tinyurl.com/o5f2zaq line 264) which says reserved_mem_size = SZ_128M)
    So current memory map is:
            • 1024M <------------------- physical RAM size
              ....................... [256M] <--- Reserved for graphic
              768 M <------------------ Available for kernel
              ....................... [128 M] <--- Reserver for GPU
              640M <------------------- Available for system
    According with the following Freescale documents:
    https://community.freescale.com/docs/DOC-93591
    uDoo team is plannig to modify working parameters to:
    -> No more "mem=" parameter
    -> fbmem = 24M
    -> GPU reserved mem size = 32M
    So in next upgrade, probably uDOO will see 968 Mega of free RAM.
    Use of swap on sd devices is not suggested, but if you temporary need one I sugegst to create a single file swap, as described in this howto
    http://www.cyberciti.biz/faq/linux-add- ... ile-howto/
    bye
    Giuseppe
  12. jimmnh
    jimmnh New Member
    Aug 16, 2013
    82
    Nice breakdown detail.
  13. aureq
    aureq New Member
    Oct 25, 2013
    17
    Hi All,
    Do we have more information regarding the CPU load ?
    This was raised in this post, but can't find any details.
    To me, the load average is a 4.00 (15 min avg) while no process seems to use that CPU.
    Thanks
  14. slanla
    slanla New Member
    Jun 10, 2013
  15. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
    With the latest version of the build and the additional update, this issue is resolved, so you dont have to adjust it manually.
    As you can see from the thread it was resolved some time ago :)
  16. Lifeboat_Jim
    Sep 16, 2013
    399
    Lets mark this as [SOLVED] and lock it too then.
  17. andcmp
    andcmp New Member
    161
    Ok!
Thread Status:
