Starting Kernel => Software Interrupt
Discussion in 'Kernels' started by schnabelvieh, Jan 20, 2015.
  1. schnabelvieh
    schnabelvieh New Member
    Jan 18, 2015
    Hello All,
    my second post ;-) I'm still fiddling with the kernel from "https://github.com/UDOOboard/Kernel_Unico"
    I've did a stage-3 gentoo install on a sata drive which works fine, if i use the precompiled kernel. Now I've changed the config a little (ip-tables ...) still using the mentioned kernel sources.
    I've did the following:
    1) linked the kernel-sources to /usr/src/linux
    2) make clean
    3) cat /proc/config.gz | gunzip > .config
    4) make -j4 uImage LOADADDR=0x12000000
    5) copied the uImage to /boot
    6) make modules && make modules_install
    7) reboot with seriell console connected ...... and ....
    the result is:
    UDOO board => run sataboot
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: ncq stag pm led clo only pmp pio slum part
    SATA Device Info:
    S/N:            44TBSNW7S
    Product model number: TOSHIBA MQ01ABF050
    Firmware version: AM002C
    Capacity: 976773168 sectors
    Booting from sata ...
    4764300 bytes read in 118 ms (38.5 MiB/s)
    ## Booting kernel from Legacy Image at 12000000 ...
       Image Name:   Linux-3.0.35-schlaubi-gentoo-g8a
       Data Size:    4764236 Bytes = 4.5 MiB
       Load Address: 12000000
       Entry Point:  12000000
       Verifying Checksum ... OK
       XIP Kernel Image ... OK
    Starting kernel ...
    software interrupt
    pc : [<1200000c>]          lr : [<1200000c>]
    sp : 4f56bbf8  ip : 7f3ffff3     fp : 1248b24c
    r10: 00000000  r9 : 4f42cd35     r8 : 4f56bf38
    r7 : 4ffb9c88  r6 : 12000000     r5 : 4ffb9c88  r4 : 00000000
    r3 : 4f56bfe0  r2 : 10000100     r1 : 000012c0  r0 : 00000000
    Flags: nZCv  IRQs off  FIQs off  Mode SVC_32
    Resetting CPU ...
    resetting ...
    U-Boot 2013.10-rc3 (Jan 20 2014 - 13:33:34)
    CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
    Reset cause: WDOG
    Board: UDOO
    DRAM:  1 GiB
    MMC:   FSL_SDHC: 0
    No panel detected: default to LDB-WVGA
    Display: LDB-WVGA (800x480)
    In:    serial
    Out:   serial
    Err:   serial
    Net:   using phy at 6
    FEC [PRIME]
    Warning: FEC MAC addresses don't match:
    Address in SROM is         00:c0:08:88:a5:d9
    Address in environment is  00:c0:08:88:9c:ce
    Note the Image name: Thus my kernel is located and loaded ......
    ups ... maybe i have to figure the meaning of
      Reset cause: WDOG
    Please: Give me some hints ;-)
    And .... Thanks in advance,
    schnabelvieh
