[TUTORIAL NEWBIE] How to set static ip in Ubuntu
Discussion in 'Linux Ubuntu' started by fatpixellin, Dec 24, 2013.
  1. fatpixellin
    fatpixellin New Member
    Dec 5, 2013
    Hi, with this basic tutorial, i will show you, how set a static ip address in Ubuntu.
    To configure your Udoo board to use a static ip address assignment, we add the static method to the inet address family statement for the appropriate interface in the file /etc/network/interfaces.
    Confirm your network interface name using below command,normally it’s eth0.
    ifconfig -a
    Open network configuration file use below command.
    sudo nano /etc/network/interfaces
    Remove the line (if have).
    iface eth0 inet dhcp
    Append below lines.
    iface eth0 inet static
    address 192.168.1.103
    netmask 255.255.255.0
    network 192.168.1.0
    broadcast 192.168.1.255
    gateway 192.168.1.1
    Ctrl+O for save, then Ctrl+X for exit.
    Restart networking service to enable the change.
    sudo /etc/init.d/networking restart
  2. Mu.Pathma
    Mu.Pathma New Member
    Jan 26, 2014
    I tried the above step when I am connected via WiFi, SSH.
    When I issue the restart command UDOO reply;
    ubuntu@udoo:~$ sudo /etc/init.d/networking restart
    * Running /etc/init.d/networking restart is deprecated because it may not enable again some interfaces
    * Reconfiguring network interfaces...
    I tried to do the same with root user, result the same, when I force restart the LAN is disconnected.
    Please advice
    Mu.Pathma
  3. lindsayhorner
    lindsayhorner New Member
    Mar 26, 2014
    I'm interested to hear how setting a static IP has been working out for other people, as I've been having real trouble. I've done it many times before on servers and Rasberry Pi's but for some reason on the Udoo it fails everytime, and I lose all connectivity.
    ifconfig -a tells me that my ethernet is 'eth6' which seems a little odd as I would have expected 'eth0'
    How has this worked for other people?
  4. peter247
    peter247 Member
    Mar 10, 2014
    263
    The Ubuntu image uses eth6 , but the debian image uses eth0 , so it can`t be uboot setting it.
    I tried to fix that , but had so many other problem I just moved to Debain.
  5. Masquime
    Masquime New Member
    May 4, 2017
    13
    Someone knows a solution that works ?
    It doesn't work for me and I really need it...
    I use a Neo Basic Board with Ubuntu
  6. waltervl
    Masquime likes this.
  7. Masquime
    Masquime New Member
    May 4, 2017
    13
    Thank you watervl, I found another way which works but your informations could be helpful
  8. waltervl
    What was that other way you used? That could also be helpful for the next one with this question.
  9. Masquime
    Masquime New Member
    May 4, 2017
    13
    It's an empirical way, but it's works for me ( and I don't know why :)) :
    I followed this Raspberry pi tuto (which I'm familiar with) to found gateway address and network address (assuming I work with a box-router) :
    so I hit the following command :
    netstat -nr
    Which gave me
    gateway : 192.168.0.1
    network : 192.168.0.0 ( what is strange because my router address is 192.168.0.1, the same as gateway)
    And I put on the /etc/network/interfaces/ file :
    auto eth0
    address 192.168.0.83
    network 192.168.0.0
    broadcast 192.168.0.255
    gateway 192.168.0.1
    And I really don't know why, but...it works
