UART connections
Discussion in 'UDOO NEO' started by pgarcia, Jul 4, 2016.
  1. pgarcia
    pgarcia New Member
    Jul 2, 2016
    15
    Hello all,
    my name is Pedro and I'm working to use the UDOO NEO in a telecomunications system. I must connect the UDOO NEO with another 2 components/systems using serial ports. Also, I must use the debug serial port to manage the system (as auxiliary management). I have the debug serial port working but I have the following problems for the other 2 serial ports:
    Thanks in advance!
  2. pgarcia
    pgarcia New Member
    Jul 2, 2016
    15
    Hello all,
    I have solved the first of my problems (UART6) applying the patch of the thread 'A9 UART6 and Udoobuntu':
    diff --git a/drivers/tty/serial/imx.c b/drivers/tty/serial/imx.c
    index b27d3fe..d89c825 100644
    --- a/drivers/tty/serial/imx.c
    +++ b/drivers/tty/serial/imx.c
    @@ -1221,7 +1221,8 @@ static int imx_startup(struct uart_port *port)
      /* Can we enable the DMA support? */
      if (is_imx6q_uart(sport) && !uart_console(port)
    -  && !sport->dma_is_inited)
    +  && !sport->dma_is_inited
    +  && !sport->port.flags == UPF_LOW_LATENCY)
      imx_uart_dma_init(sport);
      if (sport->dma_is_inited) {
    Is it possible configure another port to be used with the Linux-Ubuntu?
  3. waltervl
    Andrea Rovai likes this.
