I'm wondering if it is possible to use both the 15" LVDS and HDMI output at the same time? What is the setenv syntax to do so for a Linux environment? I've got a custom built kernel using the 12.04 Ubuntu sources compiled correctly and I've got the 15" touch screen working properly. My end goal is to utilize both video outputs at the same time and compile XBMC into my image with Sickbeard, SABNzbd, couchpotato, and headphones all running off the unit with a 4TB HD connected and a boblight LEd setup running off the arduino embedded with a custom Kiosk case.... It's coming along quite well. I just need to figure out how to do dual display. Any help appreciated.... Thanks, Jerichodee
