Ubuntu 14.04 armhf Minimal for Udoo Quad
Discussion in 'Linux Ubuntu' started by albeb89, May 16, 2014.
  1. albeb89
    albeb89 New Member
    May 7, 2014
    Hi guys,
    finaly i have uploaded the Image of Ubuntu 14.04 armhf minimal version.
    This are the account data:
    Username: ubuntu
    Password: ubuntu
    http://dfiles.eu/files/go9cj0jud
    It fit on a 8GB MicroSD
  2. rolly
    rolly New Member
    May 12, 2014
    14
    Thanks ever for this. I excitedly went to try this out but was massively put off by the download process. Any way your fine work could be uploaded to UDDO's Unofficial OS site?
    You say minimal. Will I be able to use it with a GUI, & apt-get the stuff I need?
  3. albeb89
    albeb89 New Member
    May 7, 2014
    Yeah, you can upload it where you want...the GUI can be installed from the original ubuntu repository by the apt-get command ;)
  4. rolly
    rolly New Member
    May 12, 2014
    14
    I wasn't able to download your image, nor do I have the means to upload it to UDOO.
  5. rolly
    rolly New Member
    May 12, 2014
    14
    Got it installed, installed ubuntu-desktop, did a startx & wierd behaviour unsued.
    A desktop background opened, I got the chance to logon as Ubuntu or guest, a few icons on the top right for time, speakers, & network;
    but no icons, menus, or the like that would allow me to run desktop apps, file manager, etc.
  6. rolly
    rolly New Member
    May 12, 2014
    14
    When I try to run synaptic from the command line I get "Gtk-WARNING **: cannot open display:"
    Firefox says "Error: no display specified."
  7. albeb89
    albeb89 New Member
    May 7, 2014
    I think that you have to install manually file manager & co before using it.
  8. albeb89
    albeb89 New Member
    May 7, 2014
    Synaptic is not a console application, before using it you have to installa a Desktop Envirorment like unity or xfce.
    If you want to install some packages from command line i suggest you to use apt-get or aptitude.
  9. rolly
    rolly New Member
    May 12, 2014
    14
    Forgive my lack of expertise, but my understading is that if I start off with your minimal Ubuntu, do a apt-get update,
    apt-get upgrade, an apt-get install ubuntu-desktop, and a startx; I should end up with a Unity desktop.
    What I get is a desktop with the opportunity to logon to Ubuntu, or a guest session. To the top right are menu items offering an on screen keyboard, displaying available networks, setting audio levels, etc.
    No menu items offering up applications are in sight.
    If I log on to Ubuntu, even the above mentioned menu items disappear.
    Ctrl+Alt+F1 gets me to a terminal window. Ctrl+Alt+F7 gets me back to the desktop window (still without any icons or menus that allow me to run anything).
    If I try to run an application like the nautilus file manager from the command window I get the error message "Gtk-WARNING **: cannot open display:"
    I think something is incomplete with your minimal Ubuntu 14.01 image, that prevents it from being updated to Unity.
  10. rolly
    rolly New Member
    May 12, 2014
    14
    I captured the console output from Ubuntu 12.04 soft float, and your 14.04 hard float (updated for the Unity desktop) and what follows is a log of the differences which occured at the end of the 1404 output.
    [ 3.184384] EXT3-fs (sda3): mounted filesystem with writeback data mode
    [ 3.191046] VFS: Mounted root (ext3 filesystem) on device 8:3.
    [ 3.197597] devtmpfs: mounted
    [ 3.200618] Freeing init memory: 200K
    Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
    [ 5.563937] systemd-udevd[1773]: Failed to apply ACL on /dev/rfkill: Operation not supported
    [ 5.575070] systemd-udevd[1773]: Failed to apply ACL on /dev/snd/timer: Operation not supported
    [ 6.374774] ERROR: v4l2 capture: slave not found!
    [ 6.375849] systemd-udevd[1773]: Failed to apply ACL on /dev/video1: Operation not supported
    [ 6.378466] systemd-udevd[1780]: Failed to apply ACL on /dev/video2: Operation not supported
    [ 6.380137] ERROR: v4l2 capture: slave not found!
    [ 6.381429] systemd-udevd[1776]: Failed to apply ACL on /dev/video0: Operation not supported
    * Starting Mount filesystems on boot[ OK ] * Starting Signal sysvinit that the rootfs is mounted[ OK ] * Starting Clean /tmp directory[ OK ] * Starting Populate and link to /run filesystem[ OK ] * Stopping Populate and link to /run filesystem[ OK ] * Stopping Clean /tmp directory[ OK ] * Starting Initialize or finalize resolvconf[ OK ] * Stopping Track if upstart is running in a container[ OK ] * Starting Signal sysvinit that virtual filesystems are mounted[ OK ] * Starting Signal sysvinit that virtual filesystems are mounted[ OK ] * Starting Signal sysvinit that local filesystems are mounted[ OK ] * Starting Bridge udev events into upstart[ OK ] * Starting Signal sysvinit that remote filesystems are mounted[ OK ] * Stopping Mount filesystems on boot[ OK ] * Starting flush early job output to logs[ OK ] * Starting device node and kernel event manager[ OK ] * Starting D-Bus system message bus[ OK ] * Stopping flush early job output to logs[ OK ] * Starting load modules from /etc/modules[ OK ] * Starting cold plug devices[ OK ] * Starting log initial device creation[ OK ] * Stopping load modules from /etc/modules[ OK ] * Starting SystemD login management service[ OK ] * Starting bluetooth daemon[ OK ] * Starting system logging daemon[ OK ] * Starting configure network device security[ OK ] * Starting configure network device security[ OK ] * Starting configure network device[ OK ] * Starting mDNS/DNS-SD daemon[ OK ] * Starting Reload cups, upon starting avahi-daemon to make sure remote queues are populated[ OK ] * Stopping Reload cups, upon starting avahi-daemon to make sure remote queues are populated[ OK ] * Starting CUPS printing spooler/server[ OK ] * Starting userspace bootsplash[ OK ] * Stopping cold plug devices[ OK ] * Stopping userspace bootsplash[ OK ] * Starting configure network device security[ OK ] * Starting Send an event to indicate plymouth is up[ OK ] * Stopping log initial device creation[ OK ] * Starting configure network device[ OK ] * Starting configure network device security[ OK ] * Stopping Send an event to indicate plymouth is up[ OK ] * Starting cups-browsed - Bonjour remote printer browsing daemon[ OK ] * Starting configure virtual network devices[ OK ] * Starting configure network device security[ OK ] * Starting configure network device[ OK ] * Starting Mount network filesystems[ OK ] * Starting Failsafe Boot Delay[ OK ] * Stopping Mount network filesystems[ OK ] * Starting Bridge socket events into upstart[ OK ] * Starting Bridge file events into upstart[ OK ] * Starting Mount network filesystems[ OK ] * Starting configure network device[ OK ] * Stopping Failsafe Boot Delay[ OK ] * Setting up X socket directories...
    [ OK ] * Starting System V initialisation compatibility[ OK ] * Starting modem connection manager[ OK ] * Starting configure network device security[ OK ] * Stopping Mount network filesystems[ OK ] * Stopping System V initialisation compatibility[ OK ] * Starting network connection manager[ OK ] * speech-dispatcher disabled; edit /etc/default/speech-dispatcher * Starting NTP server ntpd
    [ OK ]saned disabled; edit /etc/default/saned * Starting System V runlevel compatibility[ OK ] * Starting regular background program processing daemon[ OK ] * Starting anac(h)ronistic cron[ OK ] * Starting save kernel messages[ OK ] * Starting OpenSSH server[ OK ] * Stopping save kernel messages[ OK ] * Stopping System V runlevel compatibility[ OK ]
    Ubuntu 14.04 LTS UDOO console
    UDOO login:
  11. vinay
    vinay New Member
    Dec 20, 2014
    Freeing init memory: 208K
    after following the the below link
    https://community.freescale.com/thread/332706
    i change the setenv args as
    setenv bootargs console=ttymxc1,115200 init=/init video=mxcfb0:dev=ldb,LDB-WVGA,if=RGB666,bpp=32 video=mxcfb1:off video=mxcfb2:off fbmem=28M vmalloc=400M androidboot.console=ttymxc1 androidboot.hardware=freescale mem=1024M
    but still i am not getting my android image on 7 inch display.
    please find the log below
    U-Boot 2009.08 (Dec 18 2014 - 16:57:13)
    CPU: Freescale i.MX6 family TO1.2 at 792 MHz
    Thermal sensor with ratio = 179
    Temperature:   29 C, calibration data 0x56d4d769
    mx6q pll1: 792MHz
    mx6q pll2: 528MHz
    mx6q pll3: 480MHz
    mx6q pll8: 50MHz
    ipg clock     : 66000000Hz
    ipg per clock : 66000000Hz
    uart clock    : 80000000Hz
    cspi clock    : 60000000Hz
    ahb clock     : 132000000Hz
    axi clock   : 264000000Hz
    emi_slow clock: 132000000Hz
    ddr clock     : 528000000Hz
    usdhc1 clock  : 198000000Hz
    usdhc2 clock  : 198000000Hz
    usdhc3 clock  : 198000000Hz
    usdhc4 clock  : 198000000Hz
    nfc clock     : 24000000Hz
    Board: i.MX6Q-UDOO: unknown-board Board: 0x63012 [POR]
    Boot Device: NOR
    I2C:   ready
    DRAM:   1 GB
    MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
    *** Warning - bad CRC or MMC, using default environment
    In:    serial
    Out:   serial
    Err:   serial
    Net:   got MAC address from IIM: 00:c0:08:88:a7:ac
    FEC0 [PRIME]
    MX6Q UDOO U-Boot > setenv bootargs console=ttymxc1,115200 video=mxcfb0:dev=ldb,LDB-WVGA,if=RGB666,bpp=32 video=mxcfb1:off fbmem=28M
    MX6Q UDOO U-Boot > boot
    kernel   @ 10808000 (4333504)
    ramdisk  @ 11800000 (238367)
    kernel cmdline:
            use uboot command line:
    Starting kernel ...
    Initializing cgroup subsys cpuset
    Linux version 3.0.35 (vny@vny) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Wed Dec 17 16:46:43 IST 2014
    CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
    CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Machine: i.Mx6 UDOO Board
    Ignoring unrecognised tag 0x41000901
    Memory policy: ECC disabled, Data cache writealloc
    CPU identified as i.MX6Q, silicon rev 1.2
    PERCPU: Embedded 7 pages/cpu @c14d2000 s5408 r8192 d15072 u32768
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 223232
    Kernel command line: console=ttymxc1,115200 video=mxcfb0:dev=ldb,LDB-WVGA,if=RGB666,bpp=32 video=mxcfb1:off fbmem=28M
    PID hash table entries: 4096 (order: 2, 16384 bytes)
    Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    Memory: 640MB 240MB = 880MB total
    Memory: 878648k/878648k available, 169928k reserved, 245760K highmem
    Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
        DMA     : 0xfbe00000 - 0xffe00000   (  64 MB)
        vmalloc : 0xea800000 - 0xf2000000   ( 120 MB)
        lowmem  : 0xc0000000 - 0xea000000   ( 672 MB)
        pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
        modules : 0xbf000000 - 0xbfe00000   (  14 MB)
          .init : 0xc0008000 - 0xc003c000   ( 208 kB)
          .text : 0xc003c000 - 0xc0b4057c   (11282 kB)
          .data : 0xc0b42000 - 0xc0b988c0   ( 347 kB)
           .bss : 0xc0b988e4 - 0xc0cc8c20   (1217 kB)
    Preemptible hierarchical RCU implementation.
    NR_IRQS:624
    MXC GPIO hardware
    sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
    arm_max_freq=1GHz
    MXC_Early serial console at MMIO 0x21e8000 (options '115200')
    bootconsole [ttymxc1] enabled
    Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 512
    CPU: Testing write buffer coherency: ok
    hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
    CPU1: Booted secondary processor
    CPU2: Booted secondary processor
    CPU3: Booted secondary processor
    Brought up 4 CPUs
    SMP: Total of 4 processors activated (6324.22 BogoMIPS).
    print_constraints: dummy:
    NET: Registered protocol family 16
    print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
    print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
    print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
    print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
    print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
    print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
    UDOO board init
    ####Called set_gpios_direction
    failed to get MX6_IO_MICRO: -16
    Resetting ethernet physical layer.
    hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
    hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
    hw-breakpoint: maximum watchpoint size is 4 bytes.
    L310 cache controller enabled
    l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
    bio: create slab <bio-0> at 0
    print_constraints: vmmc: 3300 mV
    vgaarb: loaded
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    Freescale USB OTG Driver loaded, $Revision: 1.55 $
    imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
    imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
    mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
    mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
    MIPI CSI2 driver module loaded
    Advanced Linux Sound Architecture Driver Version 1.0.24.
    cfg80211: Calling CRDA to update world regulatory domain
    i2c-core: driver [max17135] using legacy suspend method
    i2c-core: driver [max17135] using legacy resume method
    Switching to clocksource mxc_timer1
    NET: Registered protocol family 2
    IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
    TCP: Hash tables configured (established 131072 bind 65536)
    TCP reno registered
    UDP hash table entries: 512 (order: 2, 16384 bytes)
    UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    RPC: Registered named UNIX socket transport module.
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    Unpacking initramfs...
    Freeing initrd memory: 232K
    PMU: registered new PMU device of type 0
    Static Power Management for Freescale i.MX6
    wait mode is enabled for i.MX6
    cpaddr = ea880000 suspend_iram_base=ea8f8000
    PM driver module loaded
    IMX usb wakeup probe
    add wake up source irq 75
    cpu regulator mode:ldo_enable
    i.MXC CPU frequency driver
    highmem bounce pool size: 64 pages
    ashmem: initialized
    JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
    fuse init (API version 7.16)
    msgmni has been set to 1236
    io scheduler noop registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    MIPI DSI driver module loaded
    mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
    _regulator_get: get() with no identifier
    mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1!
    mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
    imx-sdma imx-sdma: loaded firmware 1.1
    imx-sdma imx-sdma: initialized
    Serial: IMX driver
    imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
    imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
    console [ttymxc1] enabled, bootconsole disabled
    imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
    loop: module loaded
    request BOSSA_CLK IRQ
    registering IRQ 419 for BOSSAC Arduino erase/reset operation
    vcan: Virtual CAN interface driver
    CAN device driver interface
    flexcan netdevice driver
    FEC Ethernet Driver
    fec_enet_mii_bus: probed
    PPP generic driver version 2.4.2
    PPP Deflate Compression module registered
    PPP BSD Compression module registered
    PPP MPPE Compression module registered
    NET: Registered protocol family 24
    PPTP driver version 0.8.5
    usbcore: registered new interface driver rt2800usb
    ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
    fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    add wake up source irq 72
    fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
    fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
    fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
    fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
    hub 2-0:1.0: USB hub found
    hub 2-0:1.0: 1 port detected
    usbcore: registered new interface driver cdc_acm
    cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    usbcore: registered new interface driver usbserial
    usbserial: USB Serial Driver core
    USB Serial support registered for GSM modem (1-port)
    usbcore: registered new interface driver option
    option: v0.7.2:USB Driver for GSM modems
    USB Serial support registered for Qualcomm USB modem
    usbcore: registered new interface driver qcserial
    ARC USBOTG Device Controller driver (1 August 2005)
    android_usb gadget: Mass Storage Function, version: 2009/09/11
    android_usb gadget: Number of LUNs=1
     lun0: LUN: removable file: (no medium)
    Gadget Android: controller 'fsl-usb2-udc' not recognized
    android_usb gadget: android_usb ready
    Suspend udc for OTG auto detect
    fsl-usb2-udc: bind to driver android_usb
    mousedev: PS/2 mouse device common for all mice
    usbcore: registered new interface driver usbtouchscreen
    Sitronix touch driver 2.9.1
    Release date: 20120507
    resolution = 800 x 480
    fw revision (hex) = 0 0 9 26
    i2c protocol = 2
    max touches = 2
    input: sitronix-i2c-touch-mt as /devices/virtual/input/input0
    i2c-core: driver [isl29023] using legacy suspend method
    i2c-core: driver [isl29023] using legacy resume method
    using rtc device, snvs_rtc, for alarms
    snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
    i2c /dev entries driver
    Linux video capture interface: v2.00
    usb 2-1: new high speed USB device number 2 using fsl-ehci
    ov5640_read_reg:write reg error:reg=300a
    camera ov5640_mipi is not found
    mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
    mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
    mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
    hub 2-1:1.0: USB hub found
    hub 2-1:1.0: 4 ports detected
    i2c-core: driver [mag3110] using legacy suspend method
    i2c-core: driver [mag3110] using legacy resume method
    imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
    device-mapper: uevent: version 1.0.3
    device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
    mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
    VPU initialized
    mxc_asrc registered
    Galcore version 4.6.9.9754
    revserved_memory_account:viv_gpu registerd
    Thermal calibration data is 0x56d4d769
    Anatop Thermal registered as thermal_zone0
    anatop_thermal_probe: default cooling device is cpufreq!
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    logger: created 256K log 'log_main'
    logger: created 256K log 'log_events'
    logger: created 256K log 'log_radio'
    logger: created 256K log 'log_system'
    usbcore: registered new interface driver snd-usb-audio
    mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
    imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first.
    mmc0: host does not support reading read-only switch. assuming write-enable.
    mmc0: new high speed SDHC card at address aaaa
    mmcblk0: mmc0:aaaa SU16G 14.8 GiB
     mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
    audio_codec_ac97_cold_reset
    usb 2-1.3: new high speed USB device number 3 using fsl-ehci
    Found Audio codec AC97 vt1613, [ID = 5649 - 4123]
    asoc: vt1613 <-> imx-ssi.0 mapping ok
    Initialize HDMI-audio failed. Load HDMI-video first!
    ALSA device list:
      #0: vt1613-audio
    Netfilter messages via NETLINK v0.30.
    nf_conntrack version 0.5.0 (13732 buckets, 54928 max)
    ctnetlink v0.93: registering with nfnetlink.
    NF_TPROXY: Transparent proxy support initialized, version 4.1.0
    NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
    xt_time: kernel timezone is -0000
    IPv4 over IPv4 tunneling driver
    GRE over IPv4 demultiplexor driver
    ip_tables: (C) 2000-2006 Netfilter Core Team
    arp_tables: (C) 2002 David S. Miller
    TCP cubic registered
    NET: Registered protocol family 10
    ip6_tables: (C) 2000-2006 Netfilter Core Team
    IPv6 over IPv4 tunneling driver
    NET: Registered protocol family 17
    NET: Registered protocol family 15
    can: controller area network core (rev 20090105 abi 8)
    NET: Registered protocol family 29
    can: raw protocol (rev 20090105)
    can: broadcast manager protocol (rev 20090105 t)
    L2TP core driver, V2.0
    PPPoL2TP kernel driver, V2.0
    L2TP IP encapsulation support (L2TPv3)
    L2TP netlink interface
    L2TP ethernet pseudowire support (L2TPv3)
    lib80211: common routines for IEEE802.11 drivers
    VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    Bus freq driver module loaded
    Bus freq driver Enabled
    mxc_dvfs_core_probe
    DVFS driver module loaded
    snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
    Please suggest me what i have to up my android image.
    Thanks in advance
    vinay
  12. delba
    1,064
    Vinay, first of all please use the
    tag when you paste an entire log. I fixed it 4 you though.
  13. ekirei
    ekirei Administrator
    78
    Hi vinay, i don't think this is the right place to post about Android, this topic talking about Ubuntu 14.04.
    Your log shows that the bootargs variable set isn't complete. As you wrote before the right variable value is:
    However you can follow also this guide to set the right configuration for the 7" display:
    http://www.udoo.org/faq-items/how-do-i-set-up-my-lvds/
  14. Ryan Bartley
    Ryan Bartley New Member
    Dec 13, 2015
    Hi all,
    I am running an udoo quad and was able to install the Ubuntu 14.04 minimal version posted above, but I ran into a problem that hopefully someone here can help me diagnose. The install had no problem and i'm using xubuntu as my desktop but when i run inxi -F I get this output...
    System:    Host: UDOO Kernel: 3.0.35 armv7l (32 bit, gcc: 4.4.4)
               Desktop: Xfce 4.11.8 (Gtk 2.24.23) Distro: Ubuntu 14.04 trusty
    Machine:   No /sys/class/dmi machine data: try newer kernel, or install dmidecode
    CPU:       Quad core ARMv7 Processor rev 10 (v7l) (-MCP-) (ARM) bmips: 7953.12
               Clock Speeds: 1: 1988.28 MHz 2: 1988.28 MHz 3: 1988.28 MHz 4: 1988.28 MHz
    Graphics:  Card: Failed to Detect Video Card! X.org: 1.15.1 driver: fbdev tty size: 124x46 Advanced Data: N/A for root
    Audio:     Card-1: vt1613-audio driver: vt1613-audio Sound: ALSA ver: 1.0.24
               Card-2: imx-hdmi-soc driver: imx-hdmi-soc
    Network:   Card: Ralink RT5370 Wireless Adapter usb-ID: 002-004
               IF: N/A state: N/A mac: N/A
    Partition: ID: / size: 7.3G used: 5.9G (86%) fs: ext3
    Sensors:   None detected - is lm-sensors installed and configured?
    Info:      Processes: 133 Uptime: 1 day Memory: 381.4/875.1MB Runlevel: 2 Gcc sys: 4.8.4
               Client: Shell (bash 4.3.11) inxi: 1.9.17
    ...As you'll notice inxi was unable to detect the video card. Is there anything that I may be missing about setting up the graphics card on my udoo? Any help would be most appreciated. Thanks!
    - Ryan
