Hi, I had sidelined my Udoo Bolt V8 until I purchased the metal case for the Bolt. The bolt was working and I inserted it into the case. When I applied the power the bolt symbol on the case it. Pressing the power button on the case nothing happened. I disconnected the power and the unit will not power on at all. When I look at the power supply, which is a unit I purchased with the bolt, the LED is lit green. When I connect it to the power socket of the bolt. The led on the bolt power supply flashed on and off. When power is connected to the unit no LEDs light on the board. I removed the board from the case and disconnected the switch. I tried the micro-switch to restart the board, nothing. The reset switch makes no difference. I have re-seated the components, no joy Any help appreciated
