Bolt V8 Working with Silicon Power https://www.silicon-power.com/web/product-187SP032GBSFU266B22 Memory Specification is DDR4-2666Mhz. Works with 2400Mhz, CL17.
Bolt v8 working with Kingston KSM24SES8/8ME 8GB PC4-2400 ECC https://www.kingston.com/dataSheets/KSM24SES8_8ME.pdf
Bolt V8 Working with: Corsair Vengeance Kit of 2 x 8 GB DDR4 @ 2400 MHz CL16 CMSX16GX4M2A2400C16 Link
Hello, i also use those memories. They work just fine. For french udooers the can be found at amazon.fr
it looks like that is not the case for the 2x16GB Kit, CMSX32GX4M2A2400C16, see new UDOO BOLT GEAR not booting | UDOO Forum. Could that be fixed by a Firmware update? I checked the RAM putting them in a HP Elitebook 840 G5 and HP EliteBook 840 G6, which worked out with any problem. I can confirm that M471A2K43CB1-CTD | Samsung Semiconductor Global Website (1x16 GB, Speed: 2666 Mbps) Memory Search (kingston.com) (Part Number: KCP424SD8/16; Specs: DDR4, 2400MHz, Non-ECC, CL17, X8, 1.2V, Unbuffered, SODIMM, 260-pin, 2R, 8Gbit They can put together in the same device, I got 32 GB RAM
Crucial memory: CT8G4SFS824A Total Capacity: 8GB Specs: DDR4 PC4-19200 • CL=17 • Single Ranked • x8 based • Unbuffered • NON-ECC • DDR4-2400 • 1.2V • 1024Meg x 64 Using 2 8GB modules for total 16GB. Patriot Viper: PVS416G266C8S did NOT work. Patriot Viper Steel Series DDR4 16GB 2666MHz (PC4-21300) CL18 SODIMM. I tried a single module and couldn't get a POST.
Using 32 GB of HyperX (2x16GB), CL15 (!). Works well so far, but I have not stressed the system. I wanted 16GB, but this was a better bang for the GB between the options that I found..
I can't edit my last message (mod? combine these two, please?). But I missed adding important info. The exact make and model is: HyperX Impact 2400MHz 32GB (2x16GB) DDR4 CL15 SODIMM (Kit of 2) HX424S15IB2K2/32
Just received my Bolt Gear and installed 2 x integral 8Gb DDR4 2666MHZ IN4V8GNELSI love the part number, anyhow they are working well
Corsair Vengance (CMSX32GX4M2A2400C16) (2*16GB -> 32GB) on Bolt V8 works well, it even seems the whole system stays somewhat cooler.
