Udoo Bolt + Radeon VII + EXP GDC M2 Key A EGPU
Discussion in 'UDOO BOLT' started by Cristian Iaciu, Nov 30, 2019.
  1. Cristian Iaciu
    Cristian Iaciu UDOOer
    Nov 30, 2019
    Hello everybody,
    I wanted to upgrade the Bolt GPU so I bought a Radeon VII together with a EXP GDC M2 Key A adapter and a power source for the GPU and I am having problems on making it work on the UDOO.
    Can you help me with what settings do I have to make in BIOS and in Windows 10 in order to make it work as I disabled it for the moment because it became very frustrating as it worked for a couple of minutes and after that the screen freezes in Windows.
    Thank you very much.
    Cristian
  2. ccs_hello
    536
    194
    re: it worked for a couple of minutes and after that the screen freezes in Windows
    It's a telltale sign of possibly
    (1) PCIe bus issues (speed, termination, reflection, etc.) <-- typically the adapter design issues
    (2) poor power supply arrangement/flaky power source/poor power regulation/insufficient power, etc.
    On (1), it is well known. Some chose to use different adapter, some called the vendor o get a "better" one (newer version, shorter cable, proper signal shielding/termination, better signal path equalization.)
    On (2), know your system requirement, check if such requirement is met.
    Both cannot simply explained in few sentences. (If I sound like speaking Greek, sorry about it.)
