68682890_481181702461200_6597944638609293312_n by gunftw, on Flickr 69246648_481181715794532_6492941604574199808_n by gunftw, on Flickr 69513621_481181729127864_7070789253357109248_n by gunftw, on Flickr 68595315_481181765794527_6996171313349918720_n by gunftw, on Flickr 68767932_481181785794525_5387927737144967168_n by gunftw, on Flickr 68926230_481181809127856_7653196920457789440_n by gunftw, on Flickr This is all still WIP. Currently have to tidy up a leak so waiting on some new hardware. The alum waterblocks will be replaced by a rad shortly. And in time I hope to move away from this bulky case to a custom circular design with either radial copper tubing for cooling or heat pipes to save space and weight. This is using a micropump to move fluids and is not exactly a cost effective solution. I will look to see if I can get something cheaper in time.
Really cool. Now I want to try it. BTW, there is a company that helps make custom cooling for CPU and GPU: https://modmymods.com/cpu-water-blocks/amd-cpu-blocks.html?p=9
