Hello Udooers! I have problem, because my Neo probably is booting properly(flashing orange led), but i can't get any connection. When I'm connecting by USB, address 192.168.7.2 doesnt work, ssh and vnc not work at all. I saw that Udoo cant connect to my router over wifi. What is the problem? Is it possible to get my few files from the system and then i will reinstall Udoobuntu ?
Can you connect by wired network? That connection should work. Or connect an HDMI monitor so you can see what is going on. I don't know if you can mount the SD card on a pc to get your personal files off.
My HDMI monitor always was broken (sometimes worked, sometimes not, so i dont know), by LAN I will check
Here are some more options to recover your files from a Windows pc, including the one I already gave http://www.howtogeek.com/112888/3-ways-to-access-your-linux-partitions-from-windows/ Alternatively you could also start your pc with a linux live CD and read the SD.
