UDOO cases for sale (in small numbers!)
Discussion in 'General Discussion' started by fmc159, Mar 13, 2014.
  1. delba
    1,064
    A couple of suggestions: the HDMI hole needs to be wider, no all the HDMI cables fit on it. Same as the 2 Jack and microphone holes. The 2.5" SATA version is something i'm really looking forward to see (as well as a version with holes for LVDS and GPIOs on the lid). Great job though
  2. fmc159
    fmc159 Member
    Oct 18, 2013
    37
    Thanks very much for your suggestions. They have been implemented. A question on the SATA version. I know SATA drives have very varying thickness, but what is the amount of room people would like to me to leave for SATA drives? I don't particularly want to have to accommodate the very thickest drives because that makes the design look worse, and most of the space would be unnecessary if using slimmer drives.
  3. fmc159
    fmc159 Member
    Oct 18, 2013
    37
    Also, if I was to add a fan mount on the SATA version, I read from other posts that the built in fan plug does not enough power to get the fan up to a good speed. What are the other options for powering the fan (so I would know where to cut holes for fan cabling)?
  4. Luca72c
    Luca72c New Member
    Mar 14, 2014
    I think having room for 15mm-thick SATA drives would allow installation of practically every 2,5" HDD on the market and leave just 5,5mm unused space when using a regular 9,5mm laptop drive; 8mm space will be unused when using a 7mm SDD, but this is not a normal case...
    But if you prefer, you can leave 12,5mm room that should fit MOST of the normally used 2,5" HDDs and leave less unused space when using an SSD (just 5,5mm).
    I don't recommend leaving less room available for HDDs (ex. 9,5mm or 10mm), as this would make too many 2,5" drives on the market not compatible.
  5. peter247
    peter247 Member
    Mar 10, 2014
    263
    I from memory I think the maximum thickness of a 2.5 inch laptop drive is 12.5mm , but most drives are thinner , 9.5 mm and 8mm.
  6. Luca72c
    Luca72c New Member
    Mar 14, 2014
    There are some 2,5" hdds thicker than 12,5mm, namely for example Velociraptor and Constellation hdds that are 15mm thick. But they're rare, odd models...
    Most modern, high capacity drives are 12,5mm or 9,5mm thick, 7mm for most SSDs or low-capacity/ laptop drives. I think 12,5mm room (or a handful of mms more to be sure) would be a reasonable choice that wouldn't dissatisfy most users.
  7. juncaofish
    juncaofish New Member
    Aug 8, 2013
    Wonderful job. Could I have your mechanical scheme, so I can manufacture it in China.. :lol:
  8. fmc159
    fmc159 Member
    Oct 18, 2013
    37
    Ha, think I'll leave your offer for now juncaofish!
  9. fmc159
    fmc159 Member
    Oct 18, 2013
    37
    To all,
    Here's an album of the slightly tweaked design that should be arriving this week: http://imgur.com/a/aNCdf
    The lid mechanism has been changed and can now optionally be screwed down for a more permanent hold. HDMI and SD ports have also been expanded (following user feedback). The acrylic used has also slightly changed and looks even nicer!
  10. blade4287
    blade4287 New Member
    Oct 19, 2013
    I'm interested in one of the new cases. :) My shipping would be in the US, zipcode 98101. I'm assuming you are going via Paypal?
  11. fmc159
    fmc159 Member
    Oct 18, 2013
    37
    Hi blade4287, I'll send you a PM!
  12. rafbel58
    rafbel58 New Member
    Apr 6, 2014
    Hi fmc159,
    If the cases are ready I'll be interested in one.
    I sent you a PM earlier this day.
    Raffaello (rafbel58 for UDOO)
  13. TheJRT
    TheJRT New Member
    Nov 20, 2013
    58
    Is the 2.0 case version ready for sale ? if yes id be intrested and ill send you a pm ;)
    JRT
  14. fmc159
    fmc159 Member
    Oct 18, 2013
    37
    Hi JRT,
    The new cases have arrived at my home. I'm away until Monday or Tuesday, but will be able to start packaging and sending them then. Yes PM me to sort the details!
  15. argmodule
    argmodule New Member
    Apr 21, 2014
    hello Fergus (fmc159) can i ask a qeustion i am in development of a udoo educational kit and will be needing cases can u offer bulk prices and could u modifiy the cases logo for my product i am looking for a supplier for my new product
  16. mrdude
    mrdude New Member
    Nov 11, 2013
    11
    PM and payment send m8 - I'm looking forward to having a case, finally :)
  17. mrdude
    mrdude New Member
    Nov 11, 2013
    11
    Guys, my case just arrived today - it's very high standard design and quality - much better than I was expecting. I can recommend getting one if you are thinking about it - also don't wait too long to order as you might not get the chance again.
  18. Mds555
    Mds555 New Member
    Apr 27, 2014
    Registering interest in the Sata case when available
  19. rafbel58
    rafbel58 New Member
    Apr 6, 2014
    Hi Fergus,
    in less than 10 minutes case mounted and perfectly fit with my UDOO (used only as a player with Volumio).
    Great work! :D
    Raffaello
  20. alvaro0811
    alvaro0811 New Member
    Mar 16, 2014
    Hi there, any more cases available?
    Many thanks
