Udoo Neo Full
Discussion in 'UDOO NEO' started by MendurBerisha, Apr 7, 2016.
  1. MendurBerisha
    MendurBerisha New Member
    Mar 23, 2016
    Hello, i just recieved my Udoo Neo Full.
    I have Windows 10 installed on my pc, and when i contected it with micro usb to my pc
    the driver was installed automatically, so i don't know why i cannot acces Web Control Panel.
    I tried with and without MicroSD, but it didn't worked.
  2. Francesco
    Francesco Active Member
    Jun 23, 2015
    220
    110
    You cannot use the board without micro SD.
    Please note that there are 3 devices provided over the micro SD port: boot filesystem, serial port, network interface. You need to install the driver for the network interface in order to access the web control panel. Windows installed the drivers for the boot partition only.
  3. MendurBerisha
    Mar 23, 2016
    Where do i need to download them?
  4. Francesco
    Jun 23, 2015
    220
    110
  5. MendurBerisha
    Mar 23, 2016
  6. Francesco
    Jun 23, 2015
    220
    110
    Windows 7 maybe was used for the screenshots, but I don't think for that reason you don't have to do it in Windows 10.
    The driver is already bundled in Windows, but not installed automatically. If you follow the guide you see it.
  7. MendurBerisha
    Mar 23, 2016
    I would try it, but i don't see in Device Manager "Other Devices"
  8. Francesco
    Jun 23, 2015
    220
    110
    Maybe in Windows 10 MS changed something. I don't have Windows 10 BTW!
  9. MendurBerisha
    Mar 23, 2016
    Can UDOO Neo Full be used from External HDD.
    I mean without MicroSD, a External HDD as MicroSD?
  10. Francesco
    Jun 23, 2015
    220
    110
    Boot is supported only from SD card. Then you can use a rootfs mounted from, for example, an USB disk.
    If you use UDOO Quad, there is SATA boot supported (BTW, SD card is still used to load the boot loader).
  11. waltervl
  12. Francesco
    Jun 23, 2015
    220
    110
    I missed that patch, and it is currently unmerged. I will merge it for the next (final) release.
