Hello, I want to make an expansion board to Neo. So, I need exact dimensions of board and connector locations. Or Gerber files if available. Thanks. Jean-Pierre.
The board size is 89 x 59 mm (3.50" x 2.32") as you can check on the datasheet. I think you can also be interested in the 2D/3D model. Other resources are into the section entitled, indeed, Other Resources
