Hi, Does anyone know how to use the functions below for pwm on the udoo neo? The functions are: (those functions are in pwm.c and pwm_ifc, I think it is given when you install the udoo neo board, it is in UDOO >hardware >solox >1.6.5-00032-g71841f7> variants>udooneo> pwm.c or pwm_ifc) Code: /* //! @brief Clock sources for the PWM. kPwmClockSourceNone = 0, kPwmClockSourceIpg = 1, kPwmClockSourceCkih = 2, kPwmClockSourceCkil = 3 */ void pwm_set_clock(uint16_t instance, uint16_t clkSrc) { MY_HW_PWM_PWMCR(instance).B.CLKSRC = clkSrc; } // Set period from 0 to 0xFFFE // when this function is called, must be called pwm_set_tesolution void pwm_set_period(uint16_t instance, uint16_t period) { MY_HW_PWM_PWMPR(instance).B.PERIOD = period; pwmSetup[instance].period = period; } void pwm_enable(uint16_t instance) { MY_HW_PWM_PWMCR(instance).B.EN = 1; pwmSetup[instance].enabled = 1; } void pwm_disable(uint16_t instance) { // Disable PWM interrupt //fefrpwm_free_interrupt(instance); MY_HW_PWM_PWMCR(instance).B.EN = 0; pwmSetup[instance].enabled = 0; } // Set prescale after checking its range. // 0 - divide by 1, 1 - divide by 2, 4095 divide by 4096 void pwm_set_prescaler(uint16_t instance, uint16_t prescale) { if (prescale > PWM_MAX_PRESCALER) { printf("Invalid prescaler value.\n"); return; } MY_HW_PWM_PWMCR(instance).B.PRESCALER = prescale; } What the function pwm_set_clock is for? What the function pwm_set_period is for? How can I define a duty cycle of 50%? Where should I put the enable and disable functions? in setup or loop or in an other function? Should I put set_prescaler, set_period and set_clock in the setup function? I would like to define a pwm signal with those functions. Does someone know how to do it?
Hi there, They simply set the CR (Control Register) of the PWM module. Check the Reference Manual of the IMX6SX for further information about it. I suggest you to get a look to the analogWrite function in wiring_analog.c and do something similar. Here an example I tried: I managed to vary the frequency of the PWM using pwm_set_period, but I don't know if it's the better way to go. Code: #include "Arduino.h" #include "pwm_ifc.h" int ledPin = 9; void setup() { // set duty cycle at 50% analogWrite(ledPin, 128); } void loop() { // do a conversion uint16_t pwmChn = ardPinToPwmChn[ledPin]; // fade the period from min to max in increments of 5 points: for (int fadeValue = 0 ; fadeValue <= 100000; fadeValue += 1000) { pwm_set_period(pwmChn, fadeValue); delay(30); } // fade out the period from max to min in increments of 5 points: for (int fadeValue = 100000 ; fadeValue >= 0; fadeValue -= 1000) { // sets the value (range from 0 to 255): pwm_set_period(pwmChn, fadeValue); delay(30); } } ek5
