Udoo Neo Uboot process is not visible on the A9 serial Port
Discussion in 'UDOO NEO' started by laxmi, Apr 6, 2017.
  1. laxmi
    laxmi New Member
    Mar 25, 2017
  3. laxmi
    laxmi New Member
    Mar 25, 2017
    I followed the above link but still no luck. I am using USB-TTL which works fine, tested by shorting TX & RX pin. On my USB-TTL I can see TX led blinking on hitting keys from my PC but no RX led blink.I have tried on HyperTerminal.
  4. waltervl
    Does your Neo Boot?
  5. laxmi
    laxmi New Member
    Mar 25, 2017
    yes
  6. waltervl
    Did you try to switch the TX/RX wires?
    Neo UART1_TX should be connected to USB-TTL-RX and UART1_RX should be connected to USB-TTL-TX
    And also double check the protocol.
    Perhaps try it with Putty instead of Hyperterminal.
    I had no problems with connecting an USB-TTL to the UART1
    Andrea Rovai likes this.
  7. laxmi
    laxmi New Member
    Mar 25, 2017
    TX,RX cross connection worked.Thank you !!
  8. Jesse Millwood
    Jesse Millwood New Member
    Dec 22, 2017
    Is it possible to just have u-boot on the sdcard?
    I followed the instructions at https://github.com/UDOOboard/uboot-imx for the neo (2015.04.imx branch)
    1. wiped a micro sd card and formated it to be fat32 with gparted.
    2. then unmounted it (it is in a usb to uSD adapter)
    3. used dd to write the SPL and u-boot.img files to the sd card
    4. inserted the sd card into the neo
    5. connected the uart1 tx/rx/gnd to my usb/serial dongle (tried with a prolific one and a cypress based one)
    6. opened putty in windows and connected to the COM port with 115200 baud
    7. powered the neo up
    I don't see any output, I expected to see something like http://www.denx.de/wiki/view/DULG/UBootPowerOn where you can see the uboot prompt. I have tried swapping tx/rx just in case too and still nothing.
    I perused through the menuconfig of the uboot imx and didn't see anything really pertaining to the console.
    Is there a config somewhere I can set to just get to the uboot console with this version? I don't want to boot to any OS yet.
    Any help here would be appreciated, thanks.
  9. Jesse Millwood
    Dec 22, 2017
    Nevermind, I was in fact not on J7 but J4. everything works.
