If you stack several Udoo x86 on top of each other with the mounts available in the shop can you still use the heatsink/fan for sale? Will it cool enough for work under heavy loads? Has this been tried out? Kind regards, Paulo
Hi Paulo, the load is separated between the boards so you won't need a "super dissipator". If you already know that a great computational power will be required, then I suggest you an active dissipator (like our fan) in a closed environment, whereas outside you shouldn't need an active dissipator and the passive dissipator on board should be enough.
