Udoobuntu 2.1.2 crashes when starting ROS indigo
Discussion in 'UDOO NEO' started by rbergerpa, May 2, 2017.
  1. rbergerpa
    rbergerpa New Member
    Apr 28, 2017
    I am on a project that is using ROS Indigo (some of the libraries we use are not yet ready for later versions of ROS). I have been tasked with evaluating the possibility of replacing our current hardware stack with an Udoo Neo.
    I tried a simple example, with a sketch on the M4 logging messages to ROS. Arduino sketch is at
    https://gist.githubusercont...
    Launch file is
    <launch>
    <node pkg="rosserial_python" type="serial_node.py" name="serial_node">
    <param name="port" value="/dev/ttyMCC"/>
    <param name="baud" value="57600"/>
    </node>
    </launch>
    As soon as I launch ROS, linux crashes. All network connections are immediately terminated, and display updates stop.
    I can't find any relevant messages in any system log files.
    Can anyone help me? If I can't resolve this quickly I will have to return the Neo board and switch the project to different hardware
  3. rbergerpa
    Apr 28, 2017
    Thanks for the quick reply. Our interest in using the Neo board was the hope that the virtual serial of /dev/ttyMCC would be faster than a hardware serial port. It looks like the Neo will not be suitable for our needs because of the bugs with /dev/ttyMCC
  4. waltervl
    I can understand that. Makes me curious though what your application is that you need high speed communication. Perhaps it could wake up the Udoo team to start investing in the Neo again.
  5. rbergerpa
    Apr 28, 2017
    I decided to give the hardware serial a try, but I cannot get anything to work. To simplify testing, I then tried a simple loopback connection on the hardware for UART 6. I connected pin 33->32, 31->30, and 28->27, based on the pinout diagram at
    http://www.udoo.org/docs-neo/img/gionji/DOCS_external_pinout.PNG
    I enabled UART 6 in the device tree editor and rebooted. I then ran
    minicom -D /dev/ttymxc5 -b 57600
    I expect to see characters echoed as I type them, but I don't.
    What did I miss ?
  6. waltervl
  7. rbergerpa
    Apr 28, 2017
  8. waltervl
  9. rbergerpa
    Apr 28, 2017
    I will not have time to do that kind of debugging. We have to decide what hardware to use for our robot project in the next few days, so it looks like Udoo Neo is off the list.
    I like some of the ideas in the Neo design, but it seems the implementation is not ready for production use.
    - Bob
