UDOObuntu (Beta) is here!
Discussion in 'General Discussion' started by delba, May 29, 2014.
  1. ekirei
    ekirei Administrator
    78
    @flipsa
    we'll investigate this asap.
    we are working to recompile the Totem media player to work with the gpu Vivante support like in the previous ubuntu armel version.
    The only Desktop environment where OpenGL works properly in window is Unity, but we've give up it because is very heavy and slow.
    Try to run glxgear with the -fullscreen option to see it work with gpu accelleration.
    glxgear -fullscreen
  2. flipsa
    flipsa New Member
    Jan 14, 2014
    17
    @ekirei:
    thanks for your reply and for looking into this. let me know if i can be helpful in any way...
    that said, i have a question (searching the forums and google did not really clear this up for me) about xvideo support in the vivante module. is this just not implemented upstream by the freescale people? is this a planned feature for the future? having totem specifically support vivante is good i guess, but having a xvideo capable adaptor is really a show-stopper for many people (including me). I need VLC (or better yet xbmc) because it natively supports TVHeadend as my DVB-T streaming server running on the udoo. so, what's the state of xvideo for the GC2000 in general? i'd switch to the open source drivers (https://github.com/laanwj/etna_viv), but the GC2000 is currently not fully supported because of its multiple pixel pipelines, as far as i understand...
  3. bakercp
    bakercp New Member
    Jun 15, 2014
    For me, Beta1 booted fine, although I was unable to use any EGL context without a black screen.
    Now with Beta2, it boots fine, but lightdm fails out of the box, but ssh, etc are available.
    Two logs here:
    https://gist.github.com/bakercp/8a67f1c25fc2d2f0c5b2
    If I try to do this over ssh, I get additional failures.:
    (04:08 ubuntu@udoobuntu ~) > sudo lightdm
    ** (lightdm:3757): WARNING **: Error using VT_ACTIVATE 7 on /dev/console: Invalid argument
    ** (lightdm:3757): WARNING **: Error using VT_WAITACTIVE 7 on /dev/console: Invalid argument
  4. nicola
    nicola Member
    Apr 23, 2014
    45
    Thanks for the work ;) .
    Me too i'm interested in having EGL support. I'm trying to compile qt5 without success.
  5. TopherT1
    TopherT1 New Member
    Nov 20, 2013
    12
    Is it possible to have a LAMP stack pre-installed?
  6. flipsa
    flipsa New Member
    Jan 14, 2014
    17
    first of all: starting lightdm with "sudo lightdm" doesn't work. try "sudo service lightdm start" instead.
    however, looking at your lightdm.log these error messages are not the real problem anyway, because your xserver gets started but hangs up after about 60seconds. btw, i do get the same error messages and can start lightdm fine. to find your real problem, the lightdm.log logfile is not really helpful. check out the xorg logfile at "/var/log/Xorg.0.log" which is usually way more verbose. there's also a "/var/log/lightdm/x-0.log" but i guess the Xorg.0.log is fine.
  7. rolly
    rolly New Member
    May 12, 2014
    14
    A problem with Beta2 that I didn't have with the Beta (or with the other OS images):
    If it sees a sata drive, it boots off the 1st partition, irrespective of the existance of a
    "setenv mmcroot /dev/sda2 rootwait rw" command setting.
  8. xaxy
    xaxy New Member
    Dec 26, 2013
    love the new version BETA 2 :D .
    I would like to have sdlMame and keyboard emulation. To play arcade games with custom game pads. :ugeek:
  9. Dwek
    Dwek New Member
    Jun 22, 2014
    I have been trying to get the camera working and found that I needed to do the following before the commands mentioned on the site would work.
    sudo add-apt-repository ppa:gstreamer-developers/ppa
    sudo apt-get update
    sudo apt-get install gstreamer1.0*
    http://www.udoo.org/ProjectsAndTutorial ... ra-module/
    Thanks
  10. damoreluc
    damoreluc New Member
    Dec 9, 2013
    15
    Any chance that the usbtmc module could be added to the distro? It's useful for talking to lab instruments.
    BTW, is there a repo where I can get UDOObuntu sources and compile my preferred module?
    cheers,
    Luca
  11. Tannyveer
    Tannyveer New Member
    Feb 19, 2014
    33
    How to run openCV sample programs . I am unable to run these programs i am not found any run button when i open openCV examples
  12. nxocorp
    nxocorp New Member
    Nov 19, 2013
    Any help with supporting the Motorola Lapdock would be appreciated.
  13. lian999111
    lian999111 New Member
    Jun 5, 2014
    I'm using UDOObuntu Quad beta2.
    I have the same issue. The "command window" and the "run" button seem to disappear when I open openCV examples. I have no choice but to run the DEMOs in Terminal.
    Also, I encounter some problem when I try the camera tutorial on this official site.
    http://www.udoo.org/ProjectsAndTutorial ... lioID=1394
    I can get camera’s stream in fullscreen transparency mode with no problem.
    But when I use:
    gst-launch-0.10 mfw_v4lsrc ! ffmpegcolorspace ! ximagesink
    to get camera stream in windowed mode, the fps is very poor.
    And the terminal kept showing me that "There may be a timestamping problem, or this computer is too slow."
    I'm using the 7" LVDS touch screen instead of an HDMI screen. Don't know if that matters.
  14. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    For me it works. If you wish an easier way to use the webcam, just to:
    sudo service camera start
    This will start a gstreamer loopback device on /dev/video7 where you can access the video stream
  15. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    https://github.com/UDOOboard/Kernel_Unico
    Let us know the exact kernel module you need, we'll include into the official one
  16. damoreluc
    Dec 9, 2013
    15
    Hi mikelangeloz
    I've seen the cdc-acm added into UDOObuntu (Beta2), that's pretty. I'll find useful also usblp to enable UDOO to act as a print server and the usbtmc driver to talk to lab instruments.
    The repo you're referring to deals with the Linaro Ubuntu 12.04 LTS or with the new beta UDOObuntu?
    cheers,
    Luca
  17. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Ok, we'll include also that. The repo is referring to UDOO's kernel, we use the same on all distros
  18. lian999111
    Jun 5, 2014
    I have already tried that...
    But the video in windowed mode is still very laggy.
    The message that keep being showed in the terminal is:
    WARNING: from element /GstPipeline:pipeline0/GstXImageSink:ximagesink0: A lot of buffers are being dropped.
    Additional debug info:
    gstbasesink.c(2875): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstXImageSink:ximagesink0:
    I have been refreshing the SD image for many times :(
  19. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Mmm... I will try to replicate that, seems weird... Do you have the camera service enabled? In this case it could be that gstreamer requests too many resources... One thing you could do is update system time and date... Let me know, I'll update you also
  20. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Got it now. I had the same issue when using 7'' LVDS panel, so it seems a resolution problem, which screen resolution are you using?
