UDOObuntu (Beta) is here!
Discussion in 'General Discussion' started by delba, May 29, 2014.
  1. lian999111
    lian999111 New Member
    Jun 5, 2014
    I have already chosen the proper time zone, and it seems the system automatically updates time and date after I connected to WiFi.
    I try to refresh the SD image again, and this time I use a HDMI LCD TV instead of the 7" LVDS panel.
    I just follow the official tutorial of the camera without typing additional commands like below:
    sudo add-apt-repository ppa:gstreamer-developers/ppa
    sudo apt-get update
    sudo apt-get install gstreamer1.0*
    Surprisingly, the camera works fine. The video captured is smooth.
    However, when I switch to the 7" LVDS panel, the problem just occurs as before...
    Then, I switch back using the HDMI TV, it works fine agian
    You mentioned about enabling camera service.
    Is "sudo service camera start" used to do the job?
    No matter I use the 7" panel or the HDMI TV, when I type that,
    the terminal shows the following messages and then just hangs there until I stop it by pressing Ctrl+C so I can type other commands.
    MFW_GST_V4LSRC_PLUGIN 3.0.8 build on Nov 19 2013 12:57:36.
    Setting pipeline to PAUSED ...
    Pipeline is live and does not need PREROLL ...
    Setting pipeline to PLAYING ...
    New clock: GstSystemClock
    Another strange thing is:
    The following messages are part of the result using dmesg with the 7" LVDS panel:
    [ 2.014833] mousedev: PS/2 mouse device common for all mice
    [ 2.021031] usbcore: registered new interface driver usbtouchscreen
    [ 2.027729] Sitronix touch driver 2.9.1
    [ 2.031583] Release date: 20120507
    [ 2.035389] sitronix_reset_ic
    [ 2.159659] resolution = 800 x 480
    [ 2.163551] fw revision (hex) = 0 0 9 26
    [ 2.167475] i2c protocol = 2
    [ 2.170456] max touches = 1
    [ 2.174209] Error: Can not get ID of Sitronix IC
    [ 2.179050] input: sitronix-i2c-touch-mt as /devices/virtual/input/input0
    It shows my panel only support 1 point touch?
  2. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    When you do service camera start, you're starting a service, and the behaviour you're seeing is normal. If you let the terminal active, you can use the camera Module as a normal webcam.
    I think I got your problem, you don't have to use the above command. But you would need to change the command for gstreamer, since you want to output on LVDS and not HDMI.
    Here there are a list of useful commands:
    https://community.freescale.com/docs/DOC-93387/version/1
    It could be:
    gst-launch-0.10 mfw_v4lsrc ! mfw_v4lsink device=/dev/video17
    (or another device, try to understand which one is LVDS)
    https://developer.ridgerun.com/wiki/index.php/IMX6_GStreamer_Pipelines_-_SDK_Turrialba
    Probably you're experience laggish video because UDOO is sending the camera output to 2 screens, HDMI and LVDS. Telling him where to send video will allow for better performance. Just find out which device refers to LVDS and use the above command (maybe the syntax of gst-launch is different).
    Let me know
  3. mikelangeloz
    mikelangeloz Member
    Jul 9, 2013
    129
    Uploading UDOOBuntu 1.0 ... Added lot of new modules and fixed the bugs you submitted...
    Quite excited by results here in Siena...
  4. iCONiAN
    iCONiAN New Member
    Oct 11, 2013
    What about a real time kernel? Maybe with RTAI extensions?
  5. mmeinert
    mmeinert Member
    Jun 17, 2014
    61
    uploading done ?
    Need help with torrent seeding ?
  6. flighhyer
    flighhyer New Member
    Jan 24, 2014
  7. mmeinert
    mmeinert Member
    Jun 17, 2014
    61
    Thank you, download page is also just updated.
  8. shivaraj
    shivaraj New Member
    Jun 11, 2013
    Please seed UDOOBuntu 1.0. It's at 0 seeds right from the beginning.
  9. dantavious
    dantavious New Member
    Nov 29, 2013
    32
    Thanks for the updates on the UDOO Configuration Tool. Great Work!
  10. metalzse
    metalzse New Member
    May 25, 2014
    I am using UDOO DUAL, with UDOOBuntu 1.0.
    I can not play mp3 file with the build-in Music player, either not with the Movie player , it will cause crash of the player.
    I tried to install Rhythmbox from the Lubuntu Software Center. The software can be added into the Apps Basket, but can not be seen in the page of Apps Basket.
  11. alvaro0811
    alvaro0811 New Member
    Mar 16, 2014
    Can anyone explain how can I activate wifi? Wireless is not working out of the box. Please help!
  12. francescomm
    francescomm Member
    Dec 14, 2013
    80
    To me it worked out of the box (also on beta1). I have a Quad.
  13. alvaro0811
    Mar 16, 2014
    Many thanks francescomm.
    I also have a quad and latest beta installed. I can see the available wifi networks but cannot connect.
    Any ideas?
  14. jaeg
    jaeg Member
    Oct 22, 2013
    62
    I had to go to the networking form through the start menu and connect from there. When I select it from the other context menu it will just say "Wifi Disconnected" It's a strange behavior but I think it's just a minor glitch.
  15. Oskar
    Oskar New Member
    Jan 21, 2014
    11
    Wlan is working great! Generally seems to be very nice also, boots up quick, seems to have everything I need/want.
    However I'm trying to figure out how to get otg usb between the mx6 and sam3x. It would be nice if this worked "out of the box". (or if it does, then just some instructions)
    UART communication is very slow :/
  16. jonathan
    jonathan New Member
    Jul 15, 2014
    Hi, how can i install a webcam in udoo.
    And how can i recognize the camera and open video
    Please, Help me
  17. alvaro0811
    Mar 16, 2014
    Many thanks Jaeg. I will try that.
  18. mkopack
    mkopack Member
    451
    Go to the Webcam tool. If your camera is plugged in, it should show up in the list. If it doesn't, then the chances are that the camera you are trying to use is not UVC compatible... Only UVC cameras will work on Linux (or Mac).
  19. mkopack
    mkopack Member
    451
    Ok, finally got a chance to sit down and give this a try (the 1.0 version)... A couple comments:
    1) LOVE the Udoo Config tool. SO glad we have that now!
    2) Wifi worked for me right away.
    3) Not having any luck getting my display to go to the proper mode. I'm hooked to an HDTV 1080P via HDMI, but it always comes up in 1280x1024 and I can't seem to change to any other mode. I assume maybe I have to add something to a config file. Note this is after I used the Udooconfig tool and told it to use HDMI and 1920x1080 and then rebooted.
    4) Performance seems quite a bit snappier than it had previously.
    5) The webcam capture tool is decent, but having weird recording issues when using a USB webcam. It seems to record, but using the Video player tool it seems to just be green screen corrupted.
    6) going along with that, I see the audio meter moving as it should when I make noise, but the playback gets zero sound... In fact, I can't seem to get sound output at all over HDMI.
    7) The arduino code compile/upload is still OMG slow.
    8) The camera module works great! VERY fast.
    9) I don't know if I did something wrong when I made my 3rd USB port cable or what (I've tried like every possible pin combination) but I just can NOT seem to get anything plugged into that internal port to show up in lsusb nor work... Hope I didn't blow that port...
    10) back to the video playback tool - I've had issues where the area where the video plays will stay on top of menus and such, making it impossible to see the menu items... ie: it seems like the z-order in the video drivers are being screwed up.
    I still need to try to get either of the touchscreens working... Really need to find some way to prop them up, particularly the 15"....
    I also need to see about setting up a SATA drive... I have a couple small SSD's to try. That should make things even snappier (I've seen a couple really long hangs as the SD card is being written to...)
  20. Tannyveer
    Tannyveer New Member
    Feb 19, 2014
    33
    Hi can anybody install the qt5 on udoobuntu if done please send this post
