Hello. I'm creating a project that have the same idea as Carmadillo . I have followed each and every steps provided by the developer. unfortunately i got an error in the UDP Server ( the screen shot of the error ) https://app.box.com/s/v0g080ct6fe5jq47tc5gz88p468z7o5a I have tried all the possible ways but still the error can't be fixed. I also followed the steps here but nothing change. http://unix.stackexchange.com/questions ... mmand-line And Aslo i have changed the name of the port to /dev/ttymxc3 , and i got an error also. Here is a screen shot of it. https://app.box.com/s/e7na4skljwy7a3oqghkb07s5z4zwhwe0 Can anyone help me? i would really appreciated PS: i upload the screen shot in the box.
Hi there Casper! Your issue should be related to the Java serial library rxtx. I suggest to check this example to verify if the library is installed correctly in your system (if you are using UDOObuntu v1.1 it should be): https://github.com/UDOOboard/serial_lib ... aster/java Import in your project the right RXTXcomm.jar which is in /usr/share/java/RXTXcomm.jar If you got issues create a symlink to the serial port /dev/ttymxc3 called /dev/ttyS0 and use it in your java code. Try this, and let us know!
Hi Andrea. Thank you for your help. Actually i was following these steps. and after your reply i removed the serial library rxtx and followed the steps again. Thanks to god the problem is solved now. Cause for creating the symlink /dev/ttymxc3 , i created this time in the ubuntu directory. Once again Thank you so much.
Thanks for your patience! Can't wait to see a video of your working project!! When you feel like to sharing, the place to go is udoo.hackster.io Cheers!
