Ultrasonic sensor
Discussion in 'Arduino IDE' started by orfeus, Dec 1, 2014.
  1. orfeus
    orfeus New Member
    Feb 25, 2014
    Hi guys,
    its anybody out there who has working Ultrasonic ranging module ( HC-SR04 ) ?
    Im using bi-directional lvl shifter (3,3V< - >5V), between Udoo and sensor.
    After upload .ino sketch, its all time returned "Out of range" on my serial. I tried it with two or more examples, but result was same.
    I thing its could be problem of pulseIN() function on Arduino Due -> https://github.com/arduino/Arduino/issues/1309
    But i cant confirm it, because i have a lack of knowledge with this.
    Can someone help me?
    I like Udoo, but this little things make me crazy ..
    Thank you and have a nice day
  2. delba
    1,064
  3. hannan
    hannan New Member
    Mar 2, 2015
    when i verify the code i get this error
    Arduino: 0158 (Linux), Board: "Arduino Due (Programming Port)"
    /home/ubuntu/Arduino/libraries/NewPing/NewPing.cpp: In constructor 'NewPing::NewPing(uint8_t, uint8_t, unsigned int)':
    /home/ubuntu/Arduino/libraries/NewPing/NewPing.cpp:21:17: error: cannot convert 'RwReg* {aka volatile long unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
    _triggerOutput = portOutputRegister(digitalPinToPort(trigger_pin)); // Get the output port register for the trigger pin.
    /home/ubuntu/Arduino/libraries/NewPing/NewPing.cpp:22:13: error: cannot convert 'RoReg* {aka volatile long unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
    _echoInput = portInputRegister(digitalPinToPort(echo_pin)); // Get the input port register for the echo pin.
    /home/ubuntu/Arduino/libraries/NewPing/NewPing.cpp:24:75: error: 'portModeRegister' was not declared in this scope
    _triggerMode = (uint8_t *) portModeRegister(digitalPinToPort(trigger_pin)); // Get the port mode register for the trigger pin.
    Error compiling.
