I'm following the instructions to update to bios 1.08 using Windows 10 x64 on UDOO BOLT V8 kickstarter Step 1: I copied the files into a folder on the C: drive (the folder has full privileges) AFUWINx64.EXE amifldrv64.sys bios_updater_x64.bat C4000000.108 History.txt At step 2, as administrator, with a cmd window prompt, when I execute the bat file, I get the message" 30 - Error: Problem opening file for reading. What do other folks do at steps 1 and 2 for Windows x64 bios update 1.08? I'm sure there is a simple explanation.
Issue solved by setting the bios file as an argument to the bat file. Very simple. Apologies to the group.
