Usb HDD 3.5 dock disconnects and reconnects periodic
Discussion in 'UDOO X86' started by -Popp-, Apr 20, 2017.
  1. -Popp-
    -Popp- New Member
    Apr 17, 2017
    I've have a advanced udoo with Windows 10 installed on the 32 gb emmc. I have been experiencing a problem when I connect my Delock HHD dock with 2 pcs 3 TB Toshiba HDD with it's own power supply have been disconnecting and reconnecting. The usb dock disconnects and reconnects after a few seconds and was not registered correct in the system and was unable to unmount the drive as normal due to the drive was registered as a normal drive. This problem resolved when I changed to a different usb port.
    Has this happened to anyone else?
  2. onek
    onek New Member
    May 30, 2016
    18
    Does this happen to different USB devices on the port on which the HDDs have disconnects? If I was you I'd try several devices. Maybe the port is defective.
  3. mkopack
    mkopack Member
    451
    Also, check the power management settings in Device Manager for the USB port. It's possible that it's trying to put the port into sleep mode and that's causing it to disconnect (like OH SO MANY posts on the Oculus Rift forums on this issue)...
  4. fabio978
    fabio978 Member
    Jul 2, 2014
    51
    Also, different USB cables give different results (personal experience). Is also true that this shouldn't affect a 3.5" hdd which has its own power supply.
