I plug things into my USB host port on my NEO Full, but no power goes to the devices. UBOOT doesn't work with USB Host. I plug in stuff when Udoobuntu is running and do usb-devices and it sees the host but nothing else. Anyone else can post the output from their "usb-devices" in udoobuntu? or show output of uboot being able to see a mass storage device connected to the host?
Nevermind. Apparenly my first board is broken/burnt out somehow. My second board seems to work. However, OTG2 will not work in Uboot because nobody turns on VBUS in UBOOT for OTG2, which is (for some reason) a normal GPIO.
USB ports are not initialized by u-boot, but later by the kernel. Do you need to access USB ports in u-boot? When Linux starts, both USB ports are initialized. Do you have issues?
uboot has usb. just do "usb start" at uboot prompt. however, the only reason it does not work as far as i can tell is because the VBUS is never turned on (set GPIO6-12 or something like that). Other than that it should work. I believe the OTG port (micro USB) works as a host. board works fine once linux boots. just uboot does not work.
