Using the built in serial connection
Discussion in 'UDOO KEY' started by Logan Larsen, Jun 2, 2024.
  1. Logan Larsen
    Logan Larsen UDOOer
    Jun 2, 2024
    Hello! I am trying to build a Bluetooth media controller to connect to my phone while in the car and have buttons for skip, volume, etc...
    I am having trouble getting the internal serial connection between the two boards working. I tried on my own, and am now getting help from the google AI chat thing, with the same results. I'll post the code here, what am I doing wrong?
    I have very limited knowledge of programming these things, I'm just finding sample code from other places and pasting in what I think will work. Yes I know there's an rp2 w, but I don't have one of those and do have one of these from when it was like $9.
    for the rp2040
    #include <Arduino.h>
    const int ledPin = 25; // LED pin
    const int buttonPin = 27; // Pushbutton pin
    const int baudRate = 9600; // Match ESP32 baud rate
    int ledState = LOW; // Initial LED state (off)
    bool buttonPressed = false; // Flag to track button press
    void setup() {
      Serial.begin(baudRate); // Default serial for communication
      pinMode(ledPin, OUTPUT); // Set LED pin as output
      pinMode(buttonPin, INPUT_PULLUP); // Set button pin as input with pull-up resistor
    void loop() {
      // Check for button press (active low with pull-up)
      buttonPressed = !digitalRead(buttonPin);
      if (buttonPressed && !digitalRead(buttonPin)) { // Debounce (check twice for stable press)
        String message = "RP2040: Toggle LED"; // Message with identifier
        Serial.println(message); // Send message to ESP32
        ledState = !ledState; // Toggle LED state
        digitalWrite(ledPin, ledState); // Update LED
        delay(100); // Short delay to debounce button further (optional)
    ESP32
    const int ledPin = 32; // Blue LED pin
    const int baudRate = 9600; // Adjust if needed
    void setup() {
      Serial.begin(baudRate); // Default serial for communication with your computer (optional)
    void loop() {
      if (Serial.available()) {
        String message = Serial.readStringUntil('\n');
        Serial.println(message); // Print received message for debugging (optional)
