Hello there, I have just received my NEO from Mouser, it looks great ! I downloaded the neo minimal ubuntu image as I dont intend to use the board with monitor for now. I was trying to configure wifi connection using the link bellow (second post). http://www.udoo.org/forum/threads/openembedded-yocto-for-udoo-boards.2965/ and https://www.thinkpenguin.com/gnu-linux/how-configure-wifi-card-using-command-line-or-terminal I managed to turn on the adapter and I can scan my network. Code: udooer@udooneo:~$ ifconfig lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:65536 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) usb0 Link encap:Ethernet HWaddr 4e:71:9e:8c:10:37 inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252 inet6 addr: fe80::4c71:9eff:fe8c:1037/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:335 errors:0 dropped:4 overruns:0 frame:0 TX packets:132 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:46333 (46.3 KB) TX bytes:21827 (21.8 KB) wlan0 Link encap:Ethernet HWaddr 5c:31:3e:d5:49:99 UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) Code: udooer@udooneo:~$ sudo iw wlan0 scan | grep "SSID" SSID: UPC240860327 SSID: UPC Wi-Free SSID: MalaMaja SSID: B593-6296 SSID: bremenindahouse2.4 SSID: UPC Wi-Free SSID: OlHaRa SSID: UPC Wi-Free The problem is that when I do iwconfig I see: Code: udooer@udooneo:~$ sudo iwconfig wlan0 no wireless extensions. lo no wireless extensions. eth0 no wireless extensions. usb0 no wireless extensions. wlan0 has no wireless extensions, It fails after i try to do ifup wlan0. I assume its impossible that the driver didnt load as I can scan the network. Is there any step i have missed? I would appreciate all help!
I did exacly those steps and did not succed. How can it be checked either the proper driver is loaded? Wysłane z mojego MotoG3 przy użyciu Tapatalka
