Wifi issue
Discussion in 'Troubleshooting' started by vitotraversa, Aug 24, 2014.
  1. vitotraversa
    vitotraversa New Member
    Aug 21, 2014
    Hi all. I have a big issue with the wifi shield. I installed ubuntu on my udoo quad but the wi fi does not work. I read all the tread and forum but no way to activate it. The message i get is : wi fi not active in the icon on top right. I can not work and go far without wifi connection. Is there anyone with the same issue? I also plugged a dongle wifi in the usb port but it's dead, no signal.
    Thanks
  2. extream96
    extream96 New Member
    Jun 27, 2014
    48
    Hi, you can try to redo the sd with ubuntu, if the issue persist it could be a hw problem.
  3. davidbradway
    davidbradway New Member
    Dec 8, 2013
    I am also having problems with my wifi connection in Ubuntu on my Udoo Dual. The wired ethernet works fine, but my wifi hardware is not detected.
    Please help me get it working or please send a replacement wifi module. THanks, David
    ubuntu@udoobuntu: ~ $ nm-tool
    NetworkManager Tool
    State: connected (global)
    - Device: usb0 -----------------------------------------------------------------
    Type: Wired
    Driver: fsl-usb2-udc
    State: unavailable
    Default: no
    HW Address: D6:F7:D5:00:44:D8
    Capabilities:
    Carrier Detect: yes
    Wired Properties
    Carrier: off
    - Device: eth0 [Wired connection 1] -------------------------------------------
    Type: Wired
    Driver: fec
    State: connected
    Default: yes
    HW Address: 00:C0:08:88:2D:E0
    Capabilities:
    Carrier Detect: yes
    Speed: 100 Mb/s
    Wired Properties
    Carrier: on
    IPv4 Settings:
    Address: 192.168.1.8
    Prefix: 24 (255.255.255.0)
    Gateway: 192.168.1.1
    DNS: 192.168.1.1
  4. Andrea Rovai
    Hi there all,
    does the Wi-Fi give problem just in UDOObuntu or in any OS?
    This to exclude a hardware problem.
  5. davidbradway
    Dec 8, 2013
    I will try it on Debian soon and post the results. Thanks for your response.
    When the new version of UDOOBuntu is released, I can try it there too.
  6. Andrea Rovai
    Your welcome! Eager to share with you the new UDOObuntu!
  7. davidbradway
    Dec 8, 2013
    I tried in Debian and unfortunately, can't get it to be recognized there either. Any suggestions? I am assuming the drivers should come preinstalled in the OS images.
    debian@udoo-debian-hfp:~$ iwconfig
    lo no wireless extensions.
    eth0 no wireless extensions.
    usb0 no wireless extensions.
  8. davidbradway
    Dec 8, 2013
    more info:
    debian@udoo-debian-hfp:~$ lspci
    debian@udoo-debian-hfp:~$ ifconfig -a
    eth0 Link encap:Ethernet HWaddr 00:c0:08:88:2d:e0
    inet addr:192.168.1.12 Bcast:192.168.1.255 Mask:255.255.255.0
    UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
    RX packets:147858 errors:0 dropped:0 overruns:0 frame:0
    TX packets:32106 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:1000
    RX bytes:110110308 (105.0 MiB) TX bytes:2296077 (2.1 MiB)
    lo Link encap:Local Loopback
    LOOPBACK MTU:16436 Metric:1
    RX packets:0 errors:0 dropped:0 overruns:0 frame:0
    TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
    collisions:0 txqueuelen:0
    RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
    usb0 Link encap:Ethernet HWaddr 6a:d5:71:70:7c:ca
    debian@udoo-debian-hfp:~$ more /etc/network/interfaces
    # interfaces(5) file used by ifup(8) and ifdown(8)
    # auto lo
    # iface lo inet loopback
    # auto eth0
    # iface eth0 inet dhcp
    debian@udoo-debian-hfp:~$ dmesg | grep -i wlan
    debian@udoo-debian-hfp:~$ dmesg | grep -i wireless
  9. Andrea Rovai
    Hi there davidbradway,
    please open a ticket in the customer care section. We'll take care of you.
    Cheers
  10. davidbradway
    Dec 8, 2013
    Thank you, I just submitted the Ticket.
