WiFi (Wi-Fi) setup question: Aux or Main?
Discussion in 'UDOO X86' started by sieler, Apr 22, 2017.
Tags:
  1. sieler
    sieler New Member
    Nov 12, 2015
    15
    The video shows, in order: connecting to Wi-Fi antenna to AUX, then a closeup showing it connecting to Main, then, sigh, showing it connected to AUX. Which should it be?
    And, **HOW** do I get that tiny thing to clamp on?
    thanks!
    Stan
  2. Kilrah
    Kilrah Member
    Apr 20, 2017
    31
    16
    See the PDF instructions.
  3. sieler
    sieler New Member
    Nov 12, 2015
    15
    Thanks for the pointer to the PDF!
    TL;DR: connect to the connector labelled 'Main'. (You may need a magnifying glass to read the word :)
    For the benefit of future readers, some miscellaneous notes discovered while trying to find the pdf...
    1. The "pdf instructions" are, unfortunately, unobvious. The button labelled "Basic Setup" (with a download arrow)
    gets them for you. Or: http://cdn.udoo.org/wp-content/uploads/2017/03/1-basic_setup.pdf
    2. The button next to that *also* has a "download" icon and is labelled "Doc X86" ... but it does NOT download anything, instead it takes
    you to a page about documentation. (The page it takes you to is: http://www.udoo.org/docs-x86/Introduction/Introduction.html)
    3. The http://www.udoo.org/docs-x86/Introduction/Introduction.html page talks about four models of Udoo X86. If you have the
    low-end module, it's visually different than the other three. Otherwise, check the nice box the Udoo came in. On mine, the white label with the part# and serial# also says "Advanced Plus" in small print near the bottom.
