Windows 10 loaded as "Legacy".
Discussion in 'UDOO X86' started by yankneck696, Jun 16, 2018.
  1. yankneck696
    yankneck696 New Member
    Dec 3, 2014
    23
    Hello, it's been a bit since I loaded the OS. I do not know why it went in as "Legacy", but I would like to change that to EFI. I will also be dual booting with Unbutu 18.XX.
    WHere did I go wrong? I know I fiddled with some settings before loading & probably screwed up.
    So, should I:
    1. Change settings/update firmware?
    2. Update firmware (Should bring all settings to stock)?
    Then Ubuntu18.XX or Windows first? I will be using Windows mostly.
    I will probably put a couple other Linux distros to experiment.
    This will be controlling a Software Defined ham radio transceiver.
    Thank you,
    Ed
