@modjo to ensure you have the complete file here is the MD5 sum: Code: $ md5sum udoo-image-full-cmdline-sbca62q1gb-20160204165522.rootfs.sdcard.gz bf75e2fae500f7e5502a0157e04c6221 udoo-image-full-cmdline-sbca62q1gb-20160204165522.rootfs.sdcard.gz This is the way I usally burn the image on the SD-Card Code: mount /dev/sdd? && zcat udoo-image-full-cmdline-sbca62q1gb-20160204165522.rootfs.sdcard.gz | sudo dd of=/dev/sdd bs=32M Due to the fact I do not have a A62 I only can check if the SD-Card layout makes sense: Code: $ gunzip udoo-image-full-cmdline-sbca62q1gb-20160204165522.rootfs.sdcard.gz $ cfdisk udoo-image-full-cmdline-sbca62q1gb-20160204165522.rootfs.sdcard There was a 50% chance everything works out of the box I'll double check stuff..
Hi Graugans, the SA62 is at my work i will check this on monday ! Udooteam, it would be great if you can send this card to Grangans, in regards of it's amazing job ! this guy add a lot to the udooer community . Otherwise, this week end i remove my yocto folder to another disk (250 Go to 1To) to can build all the images. If i would to try to build an image for sa62, i have just to define the MACHINE = sbca62q1gb ?
Hi graugans, i launch a build for sa62, but i have this error (the same i had with with seco guideline !), do you know how to resolve this : WARNING: Failed to fetch URL git://secogit.seco.com/imx6_release/linux-3-14-28-secoboards-imx6_rel.git;protocol=https, attempting MIRRORS if available ERROR: Fetcher failure: Fetch command failed with exit code 128, output: Cloning into bare repository '/media/modjo/data1TO/yocto/seco/udoo-community-bsp/downloads//git2/secogit.seco.com.imx6_release.linux-3-14-28-secoboards-imx6_rel.git'... fatal: The remote end hung up unexpectedly fatal: early EOF fatal: index-pack failed ERROR: Function failed: Fetcher failure for URL: 'git://secogit.seco.com/imx6_release/linux-3-14-28-secoboards-imx6_rel.git;protocol=https'. Unable to fetch URL from any source. ERROR: Logfile of failure stored in: /media/modjo/data1TO/yocto/seco/udoo-community-bsp/sa62Build/tmp/work/sbca62q1gb-poky-linux-gnueabi/linux-seco/3.14.28-r0/temp/log.do_fetch.22316 ERROR: Task 45 (/media/modjo/data1TO/yocto/seco/udoo-community-bsp/sources/meta-udoo/recipes-kernel/linux/linux-seco_3.14.28.bb, do_fetch) failed with exit code '1' NOTE: Tasks Summary: Attempted 765 tasks of which 0 didn't need to be rerun and 1 failed. Waiting for 0 running tasks to finish:
Maybe, they have a maintainance downtime... I am not in reach of a PC to check.... Gesendet von meinem Nexus 4 mit Tapatalk
perhaps but i'm sure that tomorrow if i try i will have the same error (i already contact seco about this and no real answer to correct this since 2 month ...) If i go to https://secogit.seco.com/imx6_release/linux-3-14-28-secoboards-imx6_rel.git , i can download the zip, where i can extract it (to dowload folder ?) edit : if i try this: $ git clone https://secogit.seco.com/imx6_release/linux-3-14-28-secoboards-imx6_rel.git the result : Cloning into 'linux-3-14-28-secoboards-imx6_rel'... remote: Counting objects: 48966, done. remote: Compressing objects: 100% (44689/44689), done. fatal: The remote end hung up unexpectedly65 MiB | 201 KiB/s fatal: early EOF fatal: index-pack failed re-edit : Zip download don't work .... stop at 84.6 MB for 136.42 Mb re-re-edit ! download with tar.gz2 works ... after unzip it to dowloads/git2/ secogit.seco.com.imx6_release.linux-3-14-28-secoboards-imx6_rel.git and create a file secogit.seco.com.imx6_release.linux-3-14-28-secoboards-imx6_rel.git.done after that compilation can continue ...
After some compilations, i have another error with seco git !!! WARNING: Failed to fetch URL git://secogit.seco.com/imx6_release/linux-3-14-28-secoboards-imx6_rel.git;protocol=https, attempting MIRRORS if available ERROR: Fetcher failure: Fetch command failed with exit code 128, output: fatal: Not a git repository (or any parent up to mount point /media/modjo/data1TO) Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set). ERROR: Function failed: Fetcher failure for URL: 'git://secogit.seco.com/imx6_release/linux-3-14-28-secoboards-imx6_rel.git;protocol=https'. Unable to fetch URL from any source. ERROR: Logfile of failure stored in: /media/modjo/data1TO/yocto/seco/udoo-community-bsp/sa62Build/tmp/work/sbca62q1gb-poky-linux-gnueabi/linux-seco/3.14.28-r0/temp/log.do_fetch.7881 ERROR: Task 45 (/media/modjo/data1TO/yocto/seco/udoo-community-bsp/sources/meta-udoo/recipes-kernel/linux/linux-seco_3.14.28.bb, do_fetch) failed with exit code '1' NOTE: Tasks Summary: Attempted 1061 tasks of which 1055 didn't need to be rerun and 1 failed. Waiting for 0 running tasks to finish: Summary: 1 task failed: /media/modjo/data1TO/yocto/seco/udoo-community-bsp/sources/meta-udoo/recipes-kernel/linux/linux-seco_3.14.28.bb, do_fetch I have all the files in downloads/git2/secogit.seco.com.imx6_release.linux-3-14-28-secoboards-imx6_rel.git but i probably missing something to tell bitbake that the git is already downloaded ! edit : I think this method can't work because the folder structure is not the same when i extract the file or when bb use git, under the folder structure when i download file and extract it : and the correct structure for git : If anybody have an idea ? Udooteam, can you just try to try this $ git clone https://secogit.seco.com/imx6_release/linux-3-14-28-secoboards-imx6_rel.git to see if you have the same problem ?
After a new installation of my host pc (kubuntu 14.04 lts) i relaunch from scratch a bb. In source folder i added git clone https://secogit.seco.com/marco.sandrelli/meta-seco-bsp-release.git and on /conf/bblayers i added : $ {BSPDIR}/sources/meta-seco-bsp-release \ after this modifications, the compile work (i'm in the last step, do_rootfs), i let you know tomorrow if the card boot Graugans, i had an error with the qtwebengine patch, i need to download it manually (in download folder) ! edit : I wrote the image to the sdcard and same error : MX6Q SECO_A62 U-Boot > boot mmc0 is current device Failed to mount ext2 filesystem... ** Unrecognized filesystem type ** Wrong Image Format for bootm command ERROR: can't get kernel image! MX6Q SECO_A62 U-Boot >
perhaps the problem could be the format of the sd card. Under the format of the ubuntu image that boot on seco (they have only one partition in ext3) : and then the yocto image : in the guideline that they give, they advice to do this : (under, sd card formating) I will try to follow the same procedure for yocto ...
Sorry, I missunderstood your I thought the board was not booting at all. This ext2 is valid. Because there is an ext4 on the sd. Can you please send a full bootlog? Gesendet von meinem Nexus 4 mit Tapatalk
Graugans, you can find the log here : first, boot with functional sd (ubuntu 11.10) second boot with your yocto layer The difference with the udoo quad is that there is a boot sequence where we can use a tool --> secoq7config where we can define the boot sequence (emmc, sata, lvds ...), see the second log. if i use the uboot on emmc and the FS on the sd card yocto boot (but xith the bad uboot )!
I just saw that there are branches in the UDOO github repositories for SA62. I'll switch to them. But this may take some days...
